Fuel injector leak.. recall update
Foghorn
Canada , East Coast
Ford has demolished a small forest to send me ( and everyone else ) paperwork regarding recalls for the fuel injector leak.
They all, including the drain tube, PCM updates etc used the code letter " S " in the recall number. To me, that means a safety issue that must be fixed by Ford.
Today I asked my dealer for a status.
Surprise !!!!
All the old recalls using the S have been discontinued ( or something ) and the new recall number is 22N18. Of course , the N means " we will fix it if you have the problem ". And yes, we all have an extended 15 yr, 150K mileage ( 250KM ) warranty to cover the cost.
To me this says Ford has no plans to actually replace the injectors proactively. If you have a leak, and you can get it to a dealer without causing the incineration of your BS, they will, graciously, replace the injectors.
If a leak does result in the destruction of your BS, I assume that the finger pointing between your insurer and Ford will start. The insurer blaming Ford for not fixing a known problem. Let's hope no owner gets caught in the middle. If a leak , despite the drain tube, /PCM updates causes a fire and results in bodily harm to the occupants, you have to think liability lawyers will be all over it. Since torts of this kind usually start with " you knew or ought to have known " pretty hard for Ford to say " news to us. "
I post from Canada, and U.S. situation may be different.
Fog
Leeford
Lee
Ontario, Canada
bronco sport
I guess we'll be getting a update on this information some time soon. I still have the dated Aug 29th 2025 notice with the "S".
BigBadWolf
William
Nashville Tennessee
2023 Bronco Sport 2004 Mustang GT Convertible
Hell I'm just gonna order three injectors and replace them myself. Tired of this waiting game!
2025 Badlands Sasquatch
Arcee
Southeast, PA
2025 Bronco Sport Big Bend, Azure Gray, Convenience Pkg
The 1.5L has both high pressure injectors and low pressure injectors. The recall pertains only to the high pressure injectors and also calls for replacement of the high pressure fuel line.
