- First Name
- Wade
- Joined
- Aug 10, 2025
- Threads
- 3
- Messages
- 6
- Reaction score
- 2
- Location
- Georgia, USA
- Vehicle(s)
- 2024 Bronco Sport
- Thread starter
- #1
Question(s) for the group
I have a 24 BL with 23k on it and recently noticed low coolant. Since purchased near the end of '24 it's been at the same factory level since purchased and now as '26 starts I've noticed it was pretty low (1st photo)
I took it to my local dealer and while the service advisor guessed it was a water pump (not a known problem on the 2.0 like the 1.5) they air pressure tested it and put dye in and said they found no leaks and topped it off (2nd photo). They basically said it was at an average level, found no leaks, and there is an "actuator" that is with the reservoir that made it look the level it was.
I'm not really buying it. To me that doesn't really explain where the coolant went and I want a better answer on if the water pump or egr needs to be replaced while still under warranty and obviously to prevent a bigger problem if there is one. There has been a musty smell at times but there has been no drop off in performance, idle, engine heating, or any codes, so I'm wondering here.
Any experiences with your BL in this?
