- Thread starter
- #1
I know there have been a lot of threads about coolant leaks for the ‘21-‘24 1.5L engine, with some people having multiple replacements of the water pump without a fix. There are also some thoughts that material left over from engine block casting is causing the leak, and that a coolant flush is required before replacing the water pump. However, there have been posts from others reporting that they are still having leaks even after flushing.
I believe the latest revision of the water pump (as of this writing) is HX7Z-8501-C, which was released sometime in Fall 2025. Most of the posts I have seen on here about repeated coolant leaks predate this latest water pump revision.
So my question is: does the latest water pump revision (rev C) fix the coolant leak issue? Has anyone who has had their water pump replaced with this latest version experienced another leak?
Thanks!
Thanks!
