Bilstein b8 terrasport
Frenchy906
2025 Bronco Sport Badlands
I know you will enjoy the improvement, just dont forget to adjust your headlights. Its very easy to do.
Headlight adjustments, yes and no.
If the lift is the same front and rear (1.5” each) there is no reason to adjust them. As you’ll retain the same 2” drop over a 25’ distance to a wall. Now, if the lift isn’t the same, yes. For me, my headlights actually shine a bit lower now, and it’s been too dang cold to adjust them properly.
I gained about 1/4” more in the rear than the front, it’s not a major difference, but technically, they’re out of proper alignment now.
Garth
Garth
Ontario
I gained almost an inch more in the front than the back
Frenchy906
That’s so weird… I wonder if it’s because of the mileage? I only had 7,600 miles on mine when I installed them.
Garth
Garth
Ontario
I had maybe 5500 miles on mine. The b8 kit levels the ride height in my case from the old nose down previous
Frenchy906
Ford Bronco Sport Bilstein b8 terrasport IMG_2932
Mine definitely still sits much higher in the rear.
Garth
Garth
Ontario
Mine sits higher at the rear also but when I measured before
Ford Bronco Sport Bilstein b8 terrasport IMG_0175
Ford Bronco Sport Bilstein b8 terrasport IMG_0157
Ford Bronco Sport Bilstein b8 terrasport IMG_0154
Ford Bronco Sport Bilstein b8 terrasport IMG_0174
Garth
Garth
Ontario
Sorry for the confused order but pre lift had the Continentals
Frenchy906
So your current heights are… ~34.25” in the rear and ~33.75” up front?
Frenchy906
Ford Bronco Sport Bilstein b8 terrasport IMG_3049
Ford Bronco Sport Bilstein b8 terrasport IMG_3050
Both sides match on mine. 33.5” in front and 34.625” in rear.
Garth
Garth
Ontario
Yes which is up from 31 in the front and 33 in the back. So a 2-3/4” lift in the front and a 1-1/4” lift in the back
Frenchy906
Ford Bronco Sport Bilstein b8 terrasport IMG_2307
Ford Bronco Sport Bilstein b8 terrasport IMG_2308
I was at 32” in front and 33.5” in the rear.
DesertRat19
Will
Phoenix
Oh thanks! I didn’t think of that.
