Administrator
Administrator
Staff member
Admin
This 2021 Bronco Sport Outer Banks had its factory 18" wheels swapped out for 17x7.5 ALPHAequipt FOXTROT wheels and 245/65R17 BFG KO2 AT tire.
Ford Bronco Sport Bronco Sport Outer Banks on Aftermarket 17" Wheels and Tires Bronco Sport Outer Banks aftermarket 17 inch wheels tires
Ford Bronco Sport Bronco Sport Outer Banks on Aftermarket 17" Wheels and Tires bronco-sport-outer-banks-aftermarket-17-inch-wheels-tires1-
Ford Bronco Sport Bronco Sport Outer Banks on Aftermarket 17" Wheels and Tires bronco-sport-outer-banks-aftermarket-17-inch-wheels-tires2-
BamaBronco
TJ
Alabama
Looks great! Very aggressive. I've been considering swapping out my stock 225/65R17 with 235/70R17 A/T tires. I wonder if the these would rub when turning? I'm assuming no lift?
Administrator
Administrator
Administrator
Staff member
Admin
No lift and no rubbing on full lock according to the owner.
KH_59
Pearland, TX
1998 F-150, 2017 Explorer Limited
These wheels are +35mm offset, I presume?
BamaBronco
TJ
Alabama
Something that I just thought of as I will be purchasing some 245/65R17 A/Ts to replace the stock tires very soon...I wonder if you lose wheel suspension travel with bigger tires and no lift? Maybe not directly, but wouldn't you lose clearance at the top of the fender well when going over bumps and rough terrain?
DakotaTimber
DakotaTimber
North Dakota
BS BL + BL, 360+, tow +
Would like to see a picture of BB or OB with 235/60R18's on the 18" wheels
Shiskamba
Tennessee
2015 Ford Focus SE Hatch
Anyone know if a 245 will fit the optional 18” BB rim? I’m wanting to do 245/60/R18 on mine as I’m less concerned with potential suspension travel rub although I’ve read that doesn’t appear to be an issue even without the 1” level. If I have to go 245/55 that’s fine too. But I’d prefer to keep the factory 18 rim.
Lane4
Bbbbbb
Would like to know as well. I ordered 18 but want a more aggressive tread but without downsizing to 17. Advise on your findings.
