Clarity on Fuel Injector recall: 25S76/25V467
Would really like to see the part number for the 8F35 transmission pan filter
does "8F35" transmission have a pan filter
This is an AI response and AI isn’t always accurate …
No, the Ford 8F35 transmission does not have a conventional pan filter that is accessible by dropping the pan; instead, it uses an internal filter that requires a complete disassembly of the transmission to service. However, some parts listings refer to it as a "screen assembly" or a "cartridge" filter, indicating it is an integrated component within the transmission.
No 8F35 transmission pan filter is mentioned
The internal filter is mentioned several times
Quick Channel Update: 2020+ Ford Escape & Edge 8F35 Eight Speed Transmission Fluid
Service Procedure
harrkaep
harrkaep
christopher
maine
'22 BS
https://parts.lakelandford.com/p/Ford__Bronco-Sport/Transmission-Oil-Filter/75837325/JM5Z7A098A.html
Service Procedure
IDK man. They changed the fluid and filter.
Ford Bronco Sport Clarity on Fuel Injector recall: 25S76/25V467 Screenshot_20250824-140420
cprcubed
Parker, TX
Here's a disassembly video of a 22 Transit Connect 8F35 transmission. Notice that there is no "pan filter" (because there is no pan). There is a vertically-oriented valve body cover that has no filter behind it. The high pressure canister filter is internal (approximately 9:35 of the video). If they say they changed the filter, they're BS'ing. Cheers!
wireman
Murrieta
It's a god damn fluid and external pan filter. Not the internal one.
Probably the wrong verbiage being that your in the far northeast corner of the U.S. but chill out. No external pan filter either. Maybe fluid change and pan gasket?
harrkaep
harrkaep
christopher
maine
'22 BS
That cheap pos filter (9:35) is the transmission fluid filter? Is that a joke?
thomasm23
Los Angeles Metro
I just assumed I was talking to educated folks (no snark) who knew the internal filter is only serviceable by taking apart the transmission, as you said.
If you have to change the internal, you don't have a transmission.
Genuinely sorry we were talking about different things when I thought we were talking about the same.
Now you talk about an external ATF filter. Where is this filter located? I have changed my ATF several times and never located any external filter. Because it does not exist.
Where is the receipt?
harrkaep
harrkaep
christopher
maine
'22 BS
It must be the northeast in me. You're right. Sorry mate.
cprcubed
Parker, TX
