Clarity on Fuel Injector recall: 25S76/25V467
harrkaep
harrkaep
christopher
maine
'22 BS
thomasm23
Los Angeles Metro
Just had my ATF and ATF filter changed at 40k as well as the turbo oil filter. Also added 1oz:1qt ratio of Lubegard Platinum to the ATF
The ATF filter cannot be just changed. The transmission would have to be removed from the vehicle and disassembled to change the ATF filter. This is a permanent filter.
Please clarify what you had done to your transmission.
harrkaep
harrkaep
christopher
maine
'22 BS
My Ford dealer changed it for $199.00.
I understand you need to mount the transmission but I assume a Ford service dept can. And they did. No problem.
harrkaep
harrkaep
christopher
maine
'22 BS
So we're talking about different things regarding the $199.00 and that's my mistake. The turbo oil screen was $199.
The ATF + ATF filter was $420. This is the dealership card that they wrote the prices on. They changed the ATF and the ATF filter.
Assuming the actual fluid cost was probably 50.00, the 370.00 would make sense with labor.
Ford Bronco Sport Clarity on Fuel Injector recall: 25S76/25V467 PXL_20250824_000037686
Dealer service taking apart the trans to get to the filter, trans fluid and filter for $420 seems too cheap.
harrkaep
harrkaep
christopher
maine
'22 BS
I mean... what do you want me to say to that... Call your dealer and ask for a price.
Reactions: Me3
thomasm23
Los Angeles Metro
Can you show us the receipt for the service from the dealer?
harrkaep
harrkaep
christopher
maine
'22 BS
Dude why are you obsessed with the cost of changing my ATF filter...
To send you the receipt means I need to protectively go into my records send it to my Gmail then download it and edit out my name address and VIN.
Like I'm trying to pull one over on the forum by saying LOLLZZZ IT ACTUALLY COST ME 9908.68 not 420.00
This is bizarre
thomasm23
Los Angeles Metro
This is bizarre
Just to remove the transmission from the vehicle is at least $2000+
Why not post the receipt?
Readers on this forum need facts not alternative facts.
wireman
Murrieta
This is bizarre
Everyone here is saying that you are not getting the transmission filter changed for that price and the reasoning behind it.
It's non serviceable without major work and cost.
The $420 cost is probably for a drain and refill.
Maybe there is a easy to change screen?
harrkaep
harrkaep
christopher
maine
'22 BS
It's a god damn fluid and external pan filter. Not the internal one.
harrkaep
harrkaep
christopher
maine
'22 BS
Dude... I never said it was the internal filter. It's the fluid and pan filter.
You never said it wasn't the internal filter.
"Just had my ATF and ATF filter changed at 40k as well as the turbo oil filter. Also added 1oz:1qt ratio of Lubegard Platinum to the ATF"
"The ATF + ATF filter was $420. This is the dealership card that they wrote the prices on. They changed the ATF and the ATF filter. "
harrkaep
harrkaep
christopher
maine
'22 BS
I just assumed I was talking to educated folks (no snark) who knew the internal filter is only serviceable by taking apart the transmission, as you said.
If you have to change the internal, you don't have a transmission.
Genuinely sorry we were talking about different things when I thought we were talking about the same.
