- First Name
- Martin
- Joined
- Jun 28, 2025
- Threads
- 3
- Messages
- 46
- Reaction score
- 74
- Location
- Toronto,Ontario,Canada
- Vehicle(s)
- 2025 Bronco Sport
Thank you for this info, don't worry about a sketch, I now have a a good understanding of the function of ball plugs.What is a ball plug in terms of cylinder head manufacturing
[ChatGPT] In cylinder head manufacturing, a ball plug is typically a small spherical or ball-shaped metal plug used to seal an internal drilled passage within the cylinder head—most often in coolant or oil galleries.
Here’s why and how it’s used:
Purpose
Design & Materials
- When cylinder heads are cast and machined, internal passages (for coolant flow, oil lubrication, or sometimes fuel injection) are often created by drilling from the outside in.
- These drilled holes allow tooling to reach internal channels, but they must be sealed after machining so fluids don’t leak out.
- A ball plug is pressed into the hole to permanently block it.
Installation
- Usually made of steel, aluminum, or brass, depending on the cylinder head material.
- Spherical shape allows for uniform expansion when pressed in, providing a tight, leak-proof seal.
- Can be solid or hollow depending on application.
Examples in Cylinder Heads
- The ball is pressed into the drilled opening slightly larger than the ball’s diameter.
- Pressing deforms the ball slightly, locking it in place.
- In some cases, a sealant or staking method is added for extra security.
If you’d like, I can also sketch you a cutaway diagram of a cylinder head showing exactly where and how a ball plug is used in sealing coolant/oil galleries. That would make it visually clear.
- Coolant jacket gallery plugs – sealing the end of a drilled coolant passage.
- Oil passage plugs – closing off lubrication drill points to direct oil flow only where needed.
- Sometimes also called a ball plug closure, drill ball plug, or ball expansion plug in manufacturing manuals.
Just remember … ChatGPT does not always know truth
As far as how many Bronco Sports are impacted, I have no reason to doubt Ford’s analysis of the impacted vehicles
I appreciate your comment "ChatGTP does not always know truth ".
And here we thought that AI was going to be the answer to the world's problems ?!
Cheers
