- Thread starter
- #1
Hey all,
A few months ago I had the rough country 1.5" suspension lift kit installed on my 2022 OB. It looks great after the lift and the upgraded suspension definitely made an improvement on the ride quality. However, I noticed uneven wear on the rear tires recently, with excessive wear on the outside treads. I brought it into the Ford dealer to get an alignment, and they noted a positive camber, which I expected was likely the case. However, they are now saying that it may need aftermarket camber arms in order to have the correct alignment. Does this seem right or does anyone else have any experience with this same issue? Is it not possible to align the camber without getting new camber arms? I am not super knowledgeable about this, so I do not know if this seems reasonable.
Thank you!
Thank you!
