My 2021 Bronco sport leaks washer fluid from the front camera even when im not using the washer fluid
CapeCodKraken
Laurie
Kansas
Ford Bronco Sport Badlands
Got a record of what whey replaced this time?
It seems to be fine if it is parked on a flat surface. I ran the wipers and put it in the garage and no issue there, but expect it to work on a hill as well. It should be able to go down a hill without losing fluid.
Here is the latest repair. I believe this is an unfortunate design flaw and not bad parts. I believe my Ford technician are doing what they can. I am not sure they can modify the design to fix the issue (but I don’t know).
Ford Bronco Sport My 2021 Bronco sport leaks washer fluid from the front camera even when im not using the washer fluid IMG_0402
Trist0n
The Moon
lol, they replaced basically everything except Washer Hose - Ford (M1PZ-17A605-D) it looks like, unless 605 is a sub code of one of those. I’m 99% certain that line where the problem is, and why a 2$ part fixed this in my write up
CapeCodKraken
Laurie
Kansas
I whole heartedly believe that $2 part would do the trick (it is in my Amazon shopping list). I just need to not void my warranty since I have 2 years left. I may ask them about it. They keep telling what the problem is and I have no idea how they are coming up with the list of items they are repairing. I may have to remove the cover at the front to get a look at where you add the check valve before I start tinkering with it.
While I like the idea of a warranty, I do not like the idea of replacing perfectly functional parts.
Trist0n
The Moon
Oh yea I’m with you! I just wish they would replace that damn hose so we could tell if it’s the problem, they already have the bumper off and it’s a like 30$ part
CapeCodKraken
Laurie
Kansas
Final fix (cross your fingers). So far so good, tried it out and no leak so far.
Ford picked up my Bronco today and fixed it after I asked if there were technician notes on how to fix this problem. They got back to me and said their service technician got a fix from Ford. Here what was done this time. My car was returned with a broken grill. A nice slice straight through. Called immediately about this since I want to drive it without being blamed for the damage.
Ford Bronco Sport My 2021 Bronco sport leaks washer fluid from the front camera even when im not using the washer fluid IMG_0580
Ford Bronco Sport My 2021 Bronco sport leaks washer fluid from the front camera even when im not using the washer fluid IMG_0576
Trist0n
The Moon
Part number would be nice but hey, it looks like they finally replaced the hose. Here’s hoping I was right and that’s the fix!
Sbear
Thank you to Trist0n for their great write up. I just did the check valve fix and it was easy with their pics. You need a 10 and 7mm socket for the 2022 Badlands to get the plastic out of the way.
Ford Bronco Sport My 2021 Bronco sport leaks washer fluid from the front camera even when im not using the washer fluid 20250810_101545
