Guide to Fixing Leaky Front Camera Washer
Trist0n
The Moon
Howdy all,
I've seen this sporadically reported, but if you're like me you've got a Bronco Sport with a front camera // front camera washer. That front camera washer leaks, even while not using the washer system. Eventually it will just puke out the entire reservoir onto your garage floor. Replacing the camera washer assembly, either from Ford or on your own, does not fix the issue.
Luckily, the fix is really easy! Since replacing the washer sprayer assembly doesn't fix it, and other reports had their reservoirs or pumps replaced without fixing it, I suspect it's caused by a failing check valve somewhere in Washer Hose - Ford (M1PZ-17A605-D). Due to some funky physics, I believe that its position relative to the receiver and some pressure differences with the malfunction have it acting like a siphon, sucking out the fluid even without use of the pump. This hose is a little difficult to fully replace without removing the bumper; if someone wants to attempt and confirm go crazy, but I took a simpler route.
First, you'll want one of these universal washer check valves. Doesn't necessarily need to be this exact one, but it was cheap and easy to get ahold of. In short, you're going to snip the rubber line as close to the camera washer assembly as you can and insert this check valve inline (make sure the arrow is facing the camera!).
First, you're going to want to remove bolts and pop-tabs everywhere I've circled in red (hopefully I marked them all). We're going to remove this top fascia to access behind the grill. Once everything is unbolted and unbuttoned you should be able to slide the intake back slightly and slide out the plastic fascia.
Ford Bronco Sport Guide to Fixing Leaky Front Camera Washer IMG_4682
Note the camera washer assembly and the hose coming from the passenger side of the vehicle to it. There is a plastic sort of U clip that connects the hose to the camera. You're going to want to unclip it and remove the hose from the camera. There's also a plastic rivet holding the hose to the grille assembly; go ahead and pop that out so that we have some room to work.
You're going to snip the rubber washer hose somewhere in the middle between where it's clipped to the grille and the camera connector. The closer to the camera the better, but ensure you leave enough room for the check valve nozzle to slide in fully.
Ford Bronco Sport Guide to Fixing Leaky Front Camera Washer IMG_4669
Next, insert the check valve into the cut piece of hose with the camera connector it. ENSURE THE ARROW POINTS TOWARDS THE CAMERA CONNECTOR, THIS IS THE DIRECTION YOU WANT FLUID TO FLOW. Throw a ziptie on there to ensure everything is nice and secure.
Ford Bronco Sport Guide to Fixing Leaky Front Camera Washer IMG_4668
Finally, insert the other end of the check valve into the cut end of the hose from the body. Add another zip tie, then reconnect the plastic rivet to the grille and the washer connector to the camera assembly. Ensure everything is connected tightly so you don't get any leaks! (Pic is pre-connecting to camera assembly)
Ford Bronco Sport Guide to Fixing Leaky Front Camera Washer IMG_4670
With it all connected, go ahead and test the front washer to ensure fluid still flows correctly and nothing is leaking where you don't want it to. Once you've verified everything is secure and leak-free, bolt everything back together from the first step, and enjoy your leak free camera.
Zadazoo
Peter
Southern California
2021 Ford Bronco Sport Cyber Orange FE
I always thought the check valve totally prevented flow in one direction. Does it actually just allow flow once enough pressure (e.g. pump active) has built up?
Trist0n
Trist0n
The Moon
As I understand it’s just the one way flow, but that simple act of not allowing any pressure back flow would keep any siphoning action in check
Davexxxx
MO
2024 Bronco Sport, 2023 F150 Powerboost 501A
So how long before these things start leaking? I just verified that ours has the front camera washer. So far, not leaking but ???
Trist0n
Trist0n
The Moon
Who knows, they’re a pretty simple mechanism. No real reason why they should. Not every front camera has defective stock valving, if it’s working and not leaking then don’t touch it
I think some leaks have been traced to freezing. I would stick with low-temp washer fluid.
Davexxxx
MO
Zadazoo
Peter
Southern California
Mine started leaking after about two years, but it was minor at first. About a year later it was so bad I stopped filling the tank
Thanks for the write up. Fortunately, no dribbles for me.
johnnybegoodrn
Ricky
GMC Acadia
Hello, thank you for your guide. I just fixed my bl that leaked. I've had it since 22 and it just started to leak this month. Never did before. You are the people that make these forums well worth peoples time to visit. Again, thank you for all your help here. May GOD bless you richly as you have done for me.
Trist0n
Trist0n
The Moon
glad it was useful!
CapeCodKraken
Laurie
Kansas
Ford Bronco Sport Badlands
Apparently one year for me. Took a year to go through the first full reservoir, filled it a few weeks ago and now it is empty and I have an orange mark from the liquid on my driveway.
