- First Name
- Mark
- Joined
- Oct 30, 2021
- Threads
- 119
- Messages
- 6,727
- Reaction score
- 13,161
- Location
- St. Jacob, IL
- Vehicle(s)
- 2021 Badlands | 2020 Escape
- Thread starter
- #1
Yesterday I had my local Ford dealer send over their mobile mechanic to perform the recall work related to battery monitor software. It took all of 5 minutes. The only downside is that my auto start/stop system is now working again. Since we had unbelievably warm weather (broke a 100-year record for the St Louis area), I decided to get some other chores done, namely an oil change and tire rotation.
The good news is I found a better way to get the oil filter off without making a mess. Loosen the filter enough to turn by hand, but not enough to break the seal. Put your drain pan under the filter, then punch a hole in the bottom of it. Once you have a hole with oil draining out of the filter wait a few minutes until oil stops draining. This should get all the oil in the filter housing into the filter. At that point you can further loosen the filter to break the air seal at the top. Once the seal is broken allowing air into the top of the filter the oil within can drain out. Let it sit for five minutes or so, then you can turn the filter off with NO OIL spilling out.
The bad news came when I was rotating the tires; at some point my alignment got out of whack. All four tires exhibit significantly more wear on the inner side of the tread compared to the outer side. I'm pretty sure it's always been this way I I'm just now noticing since the tread is significantly worn; I can't see how all four wheels could get out of alignment at the same time. There were early reports (throughout 2022) of owners finding their cars were out of alignment from the factory. The tread depth on the factory AT3/W tires makes it hard to detect differences from one side to the other visually, at least until the treads get worn. I'll be comparing left/right tread depths in the future. As it is, I have one tire that is worn on the inner tread all the way to the wear markers. So, at just over 30K I need a new set of tires.
I may take this opportunity to have the wheels painted. I really like the way the Heritage Editions look with the white wheels. Regarding tires, I'm leaning toward a tire that prioritizes road manners over off-road capability since 99% of my driving is on road. My plan all along has been to buy a set of steelies and mount taller (sidewall) specialized off-road tires for those occasions when I want to play in the dirt. I haven't to date because the factory AT3/W tires did everything I wanted for off road driving, and they had great road manners as well. In fact, unlike most tires I've owned in the past, road noise with these AT3/W tires has not increased with wear--yet another reason I like them. Alas, Falken no longer makes them, so I'll likely go back to my original plan: A decent all-weather tire for everyday driving, and a set of BFG's on steelies for off-road adventures.
