Radio Issue? Sync? CarPlay?
BroncoUSA
Dan
Massachusetts
So, this morning I pulled my 23 Bronco Badlands Sport out of the garage. Went to place something in the back seat and heard a loud pop. I thought something in the garage fell.
I closed the passenger back door and started hearing a static electrical sound. It sounded like a possible electrical short.
I immediately pulled the Bronco away from the house and started trying to figure out what was happening. And started videoing in case it when up in flames or something. The original video is much longer, but this gets the point across. It’s the largest file I could upload.
After a minute or two with no smoke or smell, I deduced it might be the radio but wasn’t certain.
Shutting the engine off, turning the volume up and down, had no effect.
I was at a loss and thought I might have to disconnect the battery.
Finally I plugged in the lightning cable for the CarPlay and the sound stopped.
Is seems to be ok now. I scheduled an appointment for the Sync
Program Number: 24B47 Recall Ford recently notified me about.
I hope this will resolve the issue.
The earliest appointment is in 2 weeks.
Fingers crossed it was an isolated issue and not a real problem.
If you don’t have a lightning cable for CarPlay on hand, it might be worth having one.
BroncoUSA
Dan
Massachusetts
SYNC 3, Software Version: 3.4 Build 22251 PRODUCT
Uncle Buck
Missouri
Yikes! Certainly SOUNDS like electrical arcing. I hope it was just noise coming through the speakers. Good luck, and I look forward to an update when you get it figured out!
Fectau
Daniel
Ford Bronco sport Badlands 2021
Bronco sport Badlands 2021 Audio off , Radio problem ?
Ford Bronco Sport Radio Issue? Sync? CarPlay? 1733072497454-ai
Fectau
Daniel
The problem happened after a full night of rain with the sunroof window left open . No audio , no sound .
Ford Bronco Sport Radio Issue? Sync? CarPlay? 1733072933822-8a
Ford Bronco Sport Radio Issue? Sync? CarPlay? 1733072978419-s6
That looks like the APIM may have failed. You are probably out of warranty or do you have the Ford Premium extended warranty
Or allow everything to completely dry out and try again
Fectau
Daniel
Makes sense , GPS is not workink properly . Gives location different from where the car is.
Thanks Dude !
Thanks Dude !
Hello! Send us a private message with your VIN and current mileage. Allow me to see what I can do to assist. Thanks!
Origin
Cristian
Arkansas
2022 Bronco Sport Big Bend
Thanks Dude !
HEY FECTAU! This is a late response to the thread but I just experienced the same exact issue! How was this fixed for you?
