Tire Sidewall Crack - what would you do?
DesertRat19
Will
Phoenix
Sidewalk cracking in my rear tire and it can’t hold pressure. They have 19.6k miles so probably have to buy a pair. Not sure it’s worth getting all 4 new ones.
Curious what others would do in this situation?
I have the Falken Wikdpeaks that came when purchased for reference.
Ford Bronco Sport Tire Sidewall Crack - what would you do? IMG_7635
PaulOinMA
Paul
MA
Had a sidewall bubble on one tire at 16k on my '22 Escape. Most likely pothole damage. Tread was already half done. Bought four new tires. Continental CrossContact LX25.
DesertRat19
DesertRat19
Will
Phoenix
Unless you really can't afford to replace all four tires, I would replace all of them.
I did it when I destroyed one tire.
With only 19k miles you’d toss the 3 good ones?
PaulOinMA
Paul
MA
Measure tread depth. AWD has a tread difference spec. May be 2/32". May have to buy four. Or shave new tire, if they can do it.
Tread depth gauge is a few dollars at Autozone and the like. It's with the tire patch kits.
DesertRat19
DesertRat19
Will
Phoenix
Tire place said they’ll inspect the rest. I’ll check last ford visit to see what tread depth was since it was recent. Looking up tires and they warned about awd depth difference. First time I’ve heard of that so thanks.
BLUEOVALRACER
Ohio
I would say OP tire was damaged somehow or is a tire defect or is older than the other 3 tires.
BLUEOVALRACER
Ohio
Check all 4 tires date codes maybe that tire is older than the other 3.
DWG
New Jersey
Do you think the crack was from some type of impact damage or like BLUEOVALRACER said maybe older than the other tires? If due age of tire maybe covered by tire manufacturer warranty?
Bill G
San Gabriel Valley, CA
Another vote for “replace all four”. I hate replacing one or two, and then having them wear out/need replacing at different times — always have some w/more miles than others. Unless you can’t afford a full set, I’d do ‘em all.
wireman
Murrieta
Hard to tell but are those other cuts in the sidewall just to the right of the yellow circle?
DesertRat19
DesertRat19
Will
Phoenix
My guess is exposure to elements plus off roading.
As for tire warranty how do I find that out. These are the tires that came with vehicle during purchase in 2023. Dealership wasn’t helpful in finding out about manufacture warranty
