Adding fog lights to Big Bend
B-Dog15
Brandon
Covington, Ky
Just trying to get an idea how easy or difficult it is to install fog lights on my Big Bend? It does not have them at all at the moment.
I have found some flood lights for the Bronco Sport as well as an OEM light switch from a Bronco Sport that had fog lights that I would assume can be installed in mine.
Has anyone on here done this or had this done before? If so, how long did it take and what was the process like?
jhnvan
James
bronco sport
You'll have to find out first if you have the wiring installed in there otherwise you'll have to wire it all in. Shouldn't be too difficult but the bumper and front fascia will have to be removed completely which is a bit time consuming.
R W NORRIS New Mexico
Rodger
New Mexico
Brandon, my "fog" lights. Try a test. Start your car, turn you headlights to "low beam" or Dim and push on the Fog Light switch. Check the manual for which button. See if they activate. They are the same as the "cornering lights" that turn on when you steer left or right. They will not work on High Beam or Bright. I may be wrong, but according to what I read, all Big Bends come or did come with Fog Lights. Perhaps you are wanting an auxilliary set of lights. Let me know and I will try to help with an answer. It took me almost a year to find out about the cornering lights, since I never drove at night. lol Good Luck. Is your car a 22 or 23?
Quashish
Tomas
Sacramento
2024 Bronco Sport Badlands
or… or… just look at the front of the car and see fog lamps are absent. Looking at his profile pic I can tell there aren’t any there only blank plastic covers. Also, if the fogs aren’t equipped neither will the button on the lamp mode selector knob.
B-Dog15
B-Dog15
Brandon
Covington, Ky
Correct mine does not have fog lights at all and I am looking to add them.
And yes I do not have the push button switch BUT I did find an OEM headlight switch/ selector knob that does which I think I can just have that wired in but I am wondering if even though I don’t have fog lights, does my car still have the wiring for them already?
B-Dog15
B-Dog15
Brandon
Covington, Ky
After speaking with my local Ford they confirmed that if your Bronco Sport does not have fog lights, that there is also no wiring for said fog lights.
However I have found an aftermarket BS fog Light set from Diode Dynamics which comes with what looks like everything I would need. Now I’m just wondering if they can be wired to the new headlight switch fog light button?
jhnvan
James
bronco sport
Those don't come with the main wiring harness needed. Call them first and check though
B-Dog15
B-Dog15
Brandon
Covington, Ky
Yes I did see that. I reached out to them to see if they can give me an idea of where to get the needed harness from. Can’t seem to find it online in my short research.
B-Dog15
B-Dog15
Brandon
Covington, Ky
Reached out to Diode Dynamics and they actually sell the wiring harness needed for Bronco Sports that don’t have factory fog lights. They also said that they “believe” that this can be wired to the new OEM headlight switch if it were to be installed but they are looking into that to double check. Looks like for the kit and harness it will be about $375ish.
Mwittke5857
Elma, NY
2021 Bronco
Actually, I was able to run my wiring behind the grill. I did need to remove the airbox intake horn and the panel to which it was attached. A panel clip removing tool, a 10mm socket & ratchet was all I needed. Then again, these were aftermarket floods I mounted to the front/center of the bumper
Ford Bronco Sport Adding fog lights to Big Bend Road&Ditch_lights
Quashish
Tomas
Sacramento
OP is trying to add fog lights in factory location since vehicle didnt come equipped already with them, not add auxiliary lighting. not sure what your point is in quoting Jhnvan. read posts before you just spam irrelevant pictures.
Mwittke5857
Elma, NY
2021 Bronco
Just offering an option, cheers to you too
B-Dog15
B-Dog15
Brandon
Covington, Ky
This floods like fantastic man. You’ve done a nice job on your rig!
