Badlands (momentarily) stuck in backyard
sajohnson
sajohnson
Sherman
MIDDLETOWN, MD
Hmmm. I may be saying the same thing as you but thinking a little differently. I thought the GOAT modes activated certain things and if they did not, you could turn them on. But if the Mode turned them on, the only way to turn them off was to get out of that Mode.
I’m not sure why I thought that as it is confusing in the reading but maybe I read it here or in other discussion.
Yep, that's basically my understanding also.
I'll go out later and do some experimenting.
I like your style Meanderthal-- very diplomatic! :cool:
You are absolutely right -- the trailer was loaded incorrectly -- especially if we were planning to drive anywhere.
Here's my story:
A) We were originally planning to load some larger logs from the base of the tree on the rear of the trailer, to balance the load.
B) Then we decided that it might be best to make 2 (or more) trips.
At that point I did not feel like redistributing the load just to pull the trailer up our lane. Our '97 RAV4 used to pull a fully loaded trailer through there (maybe not quite so wet) with no problem, so I didn't think there would be a problem.
But yeah, in hindsight moving some of the wood toward the back of the trailer might have helped. It's really hard to say. With the rear locked and the front open with no traction control, the additional weight on the hitch might have helped -- even though it made the front end lighter.
I'd do some testing but we're thinking it's best to let that area dry out before we get the rest of the wood.
Also, those larger logs are really heavy and our hand truck tires (replacements, only a couple years old) lose air quickly. Side note: Has anyone tried to buy decent replacement tires for a wheelbarrow or hand truck recently? It seems like they are all made from recycled rubber bands.
I’m not a trailering pro by any means. As I said, there could be many reasons the trailer was loaded the way it was and you confirmed at least one. My reply was meant to be informative, not critical. I’m glad you took it that way.
sajohnson
sajohnson
Sherman
MIDDLETOWN, MD
Our landscaping trailer is the only thing I've ever towed. I know the basics, like: do not exceed the GVWR of the trailer; make sure the load is balanced, both side-to-side and front-to-back, with about 10% of the load on the tongue; make sure the tires are properly inflated.
We've only had the trailer on the road 2-3 times, for short distances. We use it more here around our place. I'm lucky if I can back it up without trying several times.
Your observation is a good one -- more weight on the hitch does lighten the front end. That effect can be even more pronounced if the hitch is a large distance from the rear axle. We often carry a DRZ-400 on a hitch carrier on our RV. The bike weighs ~320 lb., with the carrier and locks/chain it's about 370. Anyway, the distance to the axle is about 8 feet. I can't recall the exact number but I think it ends up being about 570# on the rear axle and the front is 200# lighter.
In my high school days I had a ‘79 Datsun P/U and I worked at a grocery store. I was asked by my manager to go to another store, across Phoenix, to pick up some soda from that store because we were low/out of it. I dutifully did as I was asked. I can remember driving back with bed of the truck loaded with cases of soda and the front end being super light. These were the days before I knew, or thought about, this sort of thing. Definitely a life lesson moment, lucky for me it didn’t turn into a disaster.
sajohnson
sajohnson
Sherman
MIDDLETOWN, MD
I had a 1985 Toyota Truck for about 25 years. It was the stripped model -- no radio or even passenger side mirror(!) -- but it was a good little truck. IIRC, the cargo capacity was 1,400+ lbs. It could carry that much easily, but I did have to be careful about weight distribution. I recall one time I got a load of gravel from the quarry and the front end was so light that the steering and braking were affected. I made it home OK (rural roads) but never did that again. We began using a piece of plywood to direct the stone up toward the cab when the loader dumped it. That worked well.
That's an extreme example of course, as is our RV with 8 feet between the rear hitch carrier and the rear axle (mentioned above).
In this case, with the BS and trailer of wood, there is much less distance from the hitch to the rear axle -- so a much lower percentage of the tongue weight is removed from the front axle.. The largest logs are directly over the trailer axle (or close to it). The remainder are between the hitch and the axle, but the weight is centered closer to the trailer axle. Had I tossed some of the wood toward the rear of the trailer before my wife pulled it through that mud, I seriously doubt it would have made any difference. BTW, she said there was no noticeable difference in the ride height, front or rear. IOW, it did not look like this F-150:
Ford Bronco Sport Badlands (momentarily) stuck in backyard 1714100580860-uz
:cool:
Without the trailer, I'm sure it would have made it through there with no problem -- some wheelspin but not getting stuck.
Also, as I mentioned above, more aggressive tires would obviously make a big difference. The OE tires just loaded up with mud and became slicks.
:cool:
I’ll see your F150 and raise you a Jetta:
Ford Bronco Sport Badlands (momentarily) stuck in backyard 1714133085133-7o
Granger Ford
Gold Sponsor
Zach
Granger Iowa
www.grangerford.com
We've been cutting up a downed ash tree in our backyard, and loaded some of the logs into our landscaping trailer to haul them up to the wood shed.
It was the first time we used the BS BL to tow the trailer, but it wasn't a full load, so we figured it would be no problem.
We didn't realize how sloppy the one section was, so we didn't think to put it in 'Mud & Ruts' instead of 'Normal'. My wife was driving and I was spotting for her. As soon as the tires started to spin, she stopped. I had her put it in 'Mud & Ruts' and lock the rear. No go. It was still spinning.
I noticed a lot of wheelspin in the front -- the traction control did not seem to be working. Maybe it doesn't in 'Mud & Ruts'? She was able to back up and try again, and that time it made it.
I was glad because the next step was going to be unloading the trailer.
My wife took a few photos. The one with our dog in it is looking southwest toward the yard where the ash tree fell.
Ford Bronco Sport Badlands (momentarily) stuck in backyard 1713924201926-x3
Thank you for the pictures! It is always nice to see what the Bronco Sport can do when it is put in action! Those ruts are pretty deep, but that did not stop it!
Slingy
Ben
North Of Boston
Next time hook the trailer up to your dog. He/she looks strong enough to pull it an even has front and rear pawsi-traction.?
sajohnson
sajohnson
Sherman
MIDDLETOWN, MD
Next test is to drive it out there to Iowa to visit family and find some fields that aren't planted yet to drive through. :cool:
Who needs this Deere when they have a BS Badlands?:
Ford Bronco Sport Badlands (momentarily) stuck in backyard 1714169647210-uz
sajohnson
sajohnson
Sherman
MIDDLETOWN, MD
That's about right! Lucy is 50% Rottweiler and 50% Boerboel (South African Mastiff). She is incredibly strong. Maybe a harness like this:
Ford Bronco Sport Badlands (momentarily) stuck in backyard 1714169956247-ei
And a Bubba Rope:
Ford Bronco Sport Badlands (momentarily) stuck in backyard 1714170195576-q9
sajohnson
sajohnson
Sherman
MIDDLETOWN, MD
So she actually takes you for a walk?
That's definitely the case with my wife, who doesn't weigh much more than Lucy. :cool:
I'm 6'2" and let's say a tad above the ideal weight and if she has good traction it's all I can do to hold her back.
We've always had large dogs, but Lucy is definitely the strongest.
My son had a rottweiller that had been trained to pull carts. I took it for a "walk" one day. That was the fastest 3 miles I ever ran. He did better without the leash.
