- First Name
- Debra
- Joined
- Sep 10, 2023
- Threads
- 0
- Messages
- 38
- Reaction score
- 24
- Location
- Los Angeles
- Vehicle(s)
- 2023 Bronco Sport
Just ordered them, thanks again!
The tufskins is another option. They're probably a lot easier to install than the vinyl, and that's reflected in the price difference. The vinyl takes a bit of care, but I've had overlays on my car for nearly two years with no hint of coming off.Just ordered them, thanks again!
I'll check those out too; can't imagine my hand being steady enough to apply these but at the cost for the vinyl ones I thought why not? I am wondering why some Bronco Sport's have just Bronco on the hatchback and others just Bronco like mine....must be different model levels?The tufskins is another option. They're probably a lot easier to install than the vinyl, and that's reflected in the price difference. The vinyl takes a bit of care, but I've had overlays on my car for nearly two years with no hint of coming off.
Some owners remove the SPORT letters. If you use an application fluid with the vinyl letters you can slide them around until they are properly position. A squeegee gets all the bubbles and most of the moisture out from under, then you just let it dry for a few days before you take it through a car wash.I'll check those out too; can't imagine my hand being steady enough to apply these but at the cost for the vinyl ones I thought why not? I am wondering why some Bronco Sport's have just Bronco on the hatchback and others just Bronco like mine....must be different model levels?
Really!? I didn't know Ford was doing that from the factory now. Are the letters centered in the cutout, or are they slight above center?Thanks! My robins egg blue Limited only came with "BRONCO" on the hatch. No SPORT.
Thanks for sharing this photo of your Bronco, Mike!If your Sport doesn't look like this, you're not having enough fun!![]()
Bronco Sport Lens TintWith "murdered" 3rd brake light, smoked tails coming soon![]()
