Adding illuminated cup holder to Badlands
EARLSAYS
Earl
Houston
A couple months ago, I bought an illuminated cup holder for an Escape, along with the pigtail. I wasn’t sure which wires to tap for power, and ultimately decided to go another direction, awapping a console harness from an Outer Banks.
at first, I thought all was good - it seemed to have every necessary connection. It doesn’t.
the rear USB connection at the back of the console is not included in the outer banks harness. Everything else is, along with one extra connector for something….wireless charger maybe?
anyway, either my illuminated cup holder is defective, or the bulkhead connector on the vehicle side lacks those pins, because I lack ambient lighting.
also, it throws a bunch of codes when you unplug all this stuff.
here’s pictures of my day of non-accomplishment.
additionally, my front camera jet is dripping washer fluid.
Ford Bronco Sport Adding illuminated cup holder to Badlands 26C60AA5-AE46-4C19-A79F-A0EE313C1BA4
Ford Bronco Sport Adding illuminated cup holder to Badlands 76B30167-FAFA-4A27-80EC-2BD5260B6F18
Ford Bronco Sport Adding illuminated cup holder to Badlands 9BE158F9-5454-4DE4-A4D5-4B6C32478E4D
Ford Bronco Sport Adding illuminated cup holder to Badlands D1AD2358-17F6-43DD-958F-9B1066D21F40
Ford Bronco Sport Adding illuminated cup holder to Badlands 9564AED4-8453-478D-AEF3-450DA2F6C0EE
Ford Bronco Sport Adding illuminated cup holder to Badlands 5B0FD67D-0AA2-4505-99B9-E5895F22934C
Ford Bronco Sport Adding illuminated cup holder to Badlands E5C9652C-879C-484F-8192-7CCE34B56A85
Ford Bronco Sport Adding illuminated cup holder to Badlands 29663BD3-BF6A-4065-B22B-9DA0C821E793
Ford Bronco Sport Adding illuminated cup holder to Badlands 52A69634-2E9B-4035-8A6A-3B6084D6BAF7
Ford Bronco Sport Adding illuminated cup holder to Badlands 88C16089-35AE-401D-84E5-127595BA2547
Ford Bronco Sport Adding illuminated cup holder to Badlands 35E2CE9E-69AB-4943-9013-18D3B6D5BD08
Ford Bronco Sport Adding illuminated cup holder to Badlands 04DC5E60-45F4-47A0-BC41-B09E1589070C
Ford Bronco Sport Adding illuminated cup holder to Badlands C6BC7294-98F7-4CA6-80A7-15AFADAA0D77
Ford Bronco Sport Adding illuminated cup holder to Badlands CB8E8A03-5B4A-40B6-946B-6A5B5CC4EA68
Ford Bronco Sport Adding illuminated cup holder to Badlands 3F77439F-446E-4240-B64B-7FADDB9C5F43
Ford Bronco Sport Adding illuminated cup holder to Badlands B6DCB7E0-3E4C-472E-A3DA-F70D64C78ECF
Ford Bronco Sport Adding illuminated cup holder to Badlands BA9D3DC7-E703-4A5C-87B8-DD55BFFFB6BC
Ford Bronco Sport Adding illuminated cup holder to Badlands D093B56A-9957-443F-A486-81702081B45C
Ford Bronco Sport Adding illuminated cup holder to Badlands 66C39477-8208-4911-87CA-A06AAD5FB5F0
Ford Bronco Sport Adding illuminated cup holder to Badlands 3C999E79-8BE2-4557-80FA-7091A46AF975
I like to make my own vehicle modifications, but the hardware and software on these cars is so tightly integrated you really need some expertise in both wrenching and coding.
additionally, my front camera jet is dripping coolant.
Coolant, or washer fluid?
EARLSAYS
EARLSAYS
Earl
Houston
I mis - spoke on that, after having a conversation about coolant, no, it’s dripping washer fluid.
mariyan75
Mariyan
Bulgaria
Has anyone managed to find a power source for a cup holder?
Quashish
Tomas
Sacramento
2024 Bronco Sport Badlands
need to tap accessory power if the related harness isn't present. not sure what happened with my factory led chips, I blew mine immediately when bench testing to try to figure out which leads to use for power since there's 3 wires on the cupholder. modified to use some different Leds i had.
Ford Bronco Sport Adding illuminated cup holder to Badlands 20241021_084346
EARLSAYS
EARLSAYS
Earl
Houston
what wires did you tap into for power?
Quashish
Tomas
Sacramento
add a fuse on passenger footwell fuse box. power on with accessory. forget which fuse number. but its the one everyone uses.
i just read through your original post didn't realize you didn't get it working. since you do have the harness its probably something in forscan you enable. pretty sure ive seen ambient lighting in the BCM settings
