BS Badlands Lift kit
Actually I have 245/65r17's on mine.
So just shy of 30".
Looks great. If you don't mind what is your total dollars for your spring set up . And how hard was the installation? Thanks
The Rinzler
Tony
Everett, WA
Oh you must be talking about Rhel's setup.
Mines completely stock, just bigger tired.
Reactions: Jrl
Rhel
Rögnvaldur
Iceland
www.facebook.com
What kit did you decide on?
Been shopping myself.
I did buy from
https://fordrangerlifts.com/
Then I did buy on eBay
  • Sway bar end links specifically for lifted Bronco Sports
  • Trailing arm spacers
  • Camber bolts
  • ABS wiring relocation brackets
after that I did levelling the wheels
gatornek
Miami
I love my BS in the street, on the road and off-road. I'm still learning the best setting in the GOAT dial when off-road.
I got the lift kit from Eibach.
PRO-LIFT-KIT
2021-2023 Ford BRONCO SPORT Badlands 2.0 T AWD C2
+1.0" Front | +0.7" Rear
Part #: E30-35-053-03-22
Set of 4 Springs
Comment: DESIGNED FOR USE WITH OE SHOCKS
Now I'm not sure about the tire size.
Should I go with 245-75-17 since I'm not planning to change the wheels.
Here's how it looks with OE tires
Ford Bronco Sport BS Badlands Lift kit PXL_20231105_162922345
Ford Bronco Sport BS Badlands Lift kit PXL_20231105_162909344
Ford Bronco Sport BS Badlands Lift kit PXL_20231105_162947529
Now that you have had it on for a bit, how would you compare the feel of the ride compared to stock?
DosJotas
Dominican Republic
The ride is as comfortable as stock and I was to go through the same trails as before without any struggling nor hitting the ground or rocks in the way.
Rolanik
Chris
I have a22 BS BL, it has the OE lift, that is somewhere between.5 and 1” greater than non BL. If I install an RTR 1.3” lift, will the vehicle then be ~2” lifted?
BS BL lift + RTR 1.3” = ~2” total.
How did Ford lift th BS BL ?
