- First Name
- Tony
- Joined
- May 21, 2023
- Threads
- 7
- Messages
- 70
- Reaction score
- 83
- Location
- Everett, WA
- Vehicle(s)
- Ford Bronco Sport
Actually I have 245/65r17's on mine..? Do you know the true diameter of your 245/70/17 .
So just shy of 30".
Looks great. If you don't mind what is your total dollars for your spring set up . And how hard was the installation? ThanksActually I have 245/65r17's on mine.
So just shy of 30".
Oh you must be talking about Rhel's setup.Looks great. If you don't mind what is your total dollars for your spring set up . And how hard was the installation? Thanks
I did buy fromWhat kit did you decide on?
Been shopping myself.
Now that you have had it on for a bit, how would you compare the feel of the ride compared to stock?I love my BS in the street, on the road and off-road. I'm still learning the best setting in the GOAT dial when off-road.
I got the lift kit from Eibach.
PRO-LIFT-KIT
2021-2023 Ford BRONCO SPORT Badlands 2.0 T AWD C2
+1.0" Front | +0.7" Rear
Part #: E30-35-053-03-22
Set of 4 Springs
Comment: DESIGNED FOR USE WITH OE SHOCKS
Now I'm not sure about the tire size.
Should I go with 245-75-17 since I'm not planning to change the wheels.
Here's how it looks with OE tires
The ride is as comfortable as stock and I was to go through the same trails as before without any struggling nor hitting the ground or rocks in the way.Now that you have had it on for a bit, how would you compare the feel of the ride compared to stock?
Badlands come with taller tires, larger-diameter shocks, more compliant anti-roll bars, and longer springs. Approximately 1/2 inch of increased ground clearance for the Badlands comes from the tires.How did Ford lift th BS BL ?
Throw a set of goodyear 30 inch workhorse tires on the badlands and get 10.5 inch and a grate ride with no rub .Badlands come with taller tires, larger-diameter shocks, more compliant anti-roll bars, and longer springs. Approximately 1/2 inch of increased ground clearance for the Badlands comes from the tires.
https://media.ford.com/content/fordmedia/fna/us/en/news/2021/08/20/high-performance-off-road-stability-suspension.html
