Raptor grill accent lights
AHerdOfMoose
Denver
Not a dumb question…but no. You need power from a source that would be switched on with the vehicle. If you powered it straight from the battery with no switch the lights will stay on even if the vehicle is off.
Ah okay yeah, that makes sense. Might look into a wireless or regular switch then, or go the route you did. Thanks!
madfella
El Paso
You can probably buy one of those “add a circuit” splicers and tap into the DRL power. I don’t know where the DRL circuit is in the fuse box but it’s just a thought.
I went into #3 fuse on the inside fuse box , that way when I start up the lights are on at start up,
Ford Bronco Sport Raptor grill accent lights IMG_0684
Ford Bronco Sport Raptor grill accent lights IMG_0670
