Not much options to set in Settings and Display Setup
kluster
Keith
Portland, OR
I have a recently purchased (few days ago) Bronco Sport Badlands 2023 with Premium Package and Towing. When I checked the options under Menu on the driver side display, the Settings only contain Oil Life and Display Setup only has Speedometer km/h. From what I read in some postings in this forum, Trip2 can be enabled in one of these menus and so are the other options such as Intelligent 4WD, Trailer Lights Check, Seat Belts, etc. The options I have are kind of pathetic and I don't even have Trip2. Does anybody have this same setup? I wonder if there's some sort of system upgrade (outside of Sync 3 as I already upgraded it to the latest) that can be done to make the other options appear. I also looked on the center console, but can't seem to find any settings that would add more options.
Ford Bronco Sport Not much options to set in Settings and Display Setup Display_Setu
Ford Bronco Sport Not much options to set in Settings and Display Setup Settings
Ford Bronco Sport Not much options to set in Settings and Display Setup Menu
There are more including Trip2 etc ... hint: did you have the engine running or the engine off when you went thru those settings?
kluster
Keith
Portland, OR
Engine was running when I went thru it.
kluster
Keith
Portland, OR
Check your owner's manual. Look for "Personalized Settings" under "Information Displays." Starts on Pg 98 in my 2021 Owner's Manual.
kluster
Keith
Portland, OR
Personalized settings on my manual is on page 109 and it mentions the various screens that can be displayed including Trip1, Trip2, Intelligent 4Wd, etc. which is what I'm looking for. However, I still can't find where this is under menu on the driver display and in the center console display.
kluster
Keith
Portland, OR
Checked again today and found that I have to scroll up from the menu to see more of the options. Thanks everyone for your help.
  1. Press the Menu button on the steering wheel.
  2. Press the Up/Down arrow and highlight "Select Screens."
  3. Use the Up/Down and OK buttons to select from available screens.
  4. Press the Back button to exit the menu.
Press the Up/Down keys to cycle through the screens you added. Note that you cannot add all the displays. I believe you are limited to five.
clipperqb
Todd
New Hampshire
2023 Bronco Sport Outer Banks, 2021 F-150 XLT
Thanks for asking the question. We just got a BS couple weeks ago and it doesn't seem as intuitive as the F150
That's exactly what I needed to do. I feel so dumb that it didn't even register in my brain to just scroll up just like int that video. Thanks again for your help!
Not at all! In my years as an instructor and tech writer I've found that different people learn differently. Some can scan through a manual and get everything they need. Others require a more visual approach. Glad to help!
mrs mighty
Sandee
Dallas
23 Bronco Sport
Thanks for the awesome help. I just love this video!! I’m learning so much here & loving it. ?
