Big Bend Oil Leak
FERNANDO
FERNANDO
COLIMA
BRONCO SPORT 2021 BIG BEND
What's up friends, I'm writing to you again, after continuing to battle with this leak, in the next service I reported this leak to the dealer again, and they only summarized themselves by saying that it is normal, after insisting so much with the shop manager, he gave me the option for me to leave my bronco for inspection with the plant technicians, but they gave me 1 to 2 months......how could it be, they were going to carry out tests and the truth is I didn't have a good feeling that They will test it with my truck, apparently it is a breather but that leak is not normal, in my case the fabric-like protector that is below the crankcase is already wet with oil in a large part.
Has it happened to anyone else that they have given you a reasonable answer?
FERNANDO
FERNANDO
COLIMA
Greetings from Colima Mexico
Ford Bronco Sport Big Bend Oil Leak 1697601743227
Unless you are riding a Harley-Davidson motorcycle, there's no such thing as a "normal" oil leak.
FERNANDO
FERNANDO
COLIMA
It's correct, just that it was a Harley, if anyone else has this problem I would appreciate it if you could give us your comments or if the agency gave you a solution.
Deleted member 12075
I noticed the same thing, it appears my breather is working properly as well! :crackup:
RushMan
Russ
NW NJ
'24 Shadow Black Badlands
Unless it's a Wright Cyclone, or Pratt & Whitney Wasp radial.
21Broncosaurus
Ish
SoCal
21 Bronco Sport
It’s normal to see weepage from that area. That’s the breather/fill port for the transmission.
MDTX27
Yup.. confirmed it’s just transmission fluid from the fill/breather tube. Great video on how to drain and fill the transmission.
