- Thread starter
- #16
Thank you!
Thank you!
Thanks! I’ve already put over 300 miles on that e-bike in under 60 days!Your setup to enjoy the outdoors for sure. Doesn't get much better than what you have there.
the dealership installed the HRG off-road 1.5 inch lift kitWhat lift kit did the dealer install?
My understanding was that a lift wasn't possible on the Badlands.
Just curious.
Thanks for the info. Glad to see there's a lift out there for the badlands.the dealership installed the HRG off-road 1.5 inch lift kit
https://www.hrgoffroad.com/1.5-inch-38mm-lift-kit-for-2021-2023-ford-bronco-sport/
I love everything about your BS BL -- nice job!Yes, connected the Timberline towers directly to the factory roof rack. I chose to do this because it allowed the platform to sit 5 1/2" lower. Otherwise I couldn't get it into my garage without taking the equipment off. I have a few up close photos of the setup in the posts above.
Thank you! I’ve had so much fun with this truck!I love everything about your BS BL -- nice job!
I imagine I should know what in the photo but I can't figure it out.
How is the bike rack working out? I'm considering the 122 if we go ahead and replace the Suzuki with 2 ebikes.
Glad to hear it!Thank you! I’ve had so much fun with this truck!
The photo is showing how close the Yakima kayak mount is to the top of my garage door. If I used the cross bars in combination with my lock-n-load I’d never fit into the garage.
so far the bike and rack have been amazing!
The HRG lifts for the Heritage Unlimited, Badlands and First Edition are slightly less because they are already lifted a bit from the factory. Same for the other brands. Adding a lift does not give you increased clearance for bigger tires. The rubbing is not on the top but on the inside sides.Thanks for the info. Glad to see there's a lift out there for the badlands.
Did you upsize the tires?
Not sure what your are trying to convey and not to split hairs, but the lift kit (on the stock tires) raised my truck 1 1/4 inches. I measured before and after. Once I added my BFG K02s it went up another 1/2 inch. I’m now sitting 1 3/4 inches higher than stock.The HRG lifts for the Heritage Unlimited, Badlands and First Edition are slightly less because they are already lifted a bit from the factory. Same for the other brands. Adding a lift does not give you increased clearance for bigger tires. The rubbing is not on the top but on the inside sides.
lol, it still has that new car smell… haven’t even eaten any food in it yet. I’ll get it dirty some day ?Looks great in the parking lot, where's the dirt?, lol. Have fun with your build.
Trying to convey that adding a lift does not increase the maximum tire size and that the lift for the Badlands is 1 1/4 as you measured not 1 1/2 as stated. Just trying to make sure people understand. Many people think by adding a 1 1/2 lift means you can go equally in tire diameter but that is not the case.Not sure what your are trying to convey and not to split hairs, but the lift kit (on the stock tires) raised my truck 1 1/4 inches. I measured before and after. Once I added my BFG K02s it went up another 1/2 inch. I’m now sitting 1 3/4 inches higher than stock.
