Fabric Wheel Well Upkeep and Tips
Bubmoo
Atlanta
Bronco Sport Base
I go offroading pretty consistently in mud now that I’ve got my 1.5 inch lift, but have recently noticed that the fabric wheelwells (or whatever you call them) continue to get loose and get pulled apart from the screw, or fall off the screw while it is still there. Does anybody have any tips to prevent this, the part numbers for replacement fabric wheelwells, the screws that are used for under, and anything else regarding this? I drive the base model with the 1.5 L.
Ford Bronco Sport Fabric Wheel Well Upkeep and Tips IMG_7908
Ford Bronco Sport Fabric Wheel Well Upkeep and Tips IMG_7907
Ford Bronco Sport Fabric Wheel Well Upkeep and Tips IMG_7906
Poolmanz Sport Bronco
Bruce
Castro Valley, CA
sites.google.com
'21 Bronco Sport FE Area 51
After my first real muddy trail run and then pressure washing the wheel wells and underneath …. I realized these are “wear and TEAR” items. If I’m gonna play I got to pay.
I recommend you check out JCR OFF-ROAD and HRG Off-road for under armor if you are off-roading like that.
Yup. I posted a couple of years back these should be considered wear items, like brakes and batteries. My post was soundly panned. Ford—like almost every other manufacturer—switched to these because they are lightweight compared to metal liners, and they don't corrode. Because they're made of fabric, they will dry, so they won't hold moisture against metal parts which would promote corrosion. All-in-all, these solve a lot of engineering problems, but they're not "durable," so many owners don't like them.
Bubmoo
Bubmoo
Atlanta
Bronco Sport Base
noted, thank you!
Wear items is fine with me. Do you happen to have the full list of part numbers that would be useful to owners needing replacement fabric? Probably most of the fabric is the same part numbers for different bronco sport models ‘21-‘24 with some unique to specific models. If you didn’t pull that part # list together that’s fine, just asking if you have it. Thanks!
No, I don't have a list. I believe one of our members has a copy of the shop manual (@Bucko?). That should make it easy to pull together a parts list.
That would be awesome if @Bucko could do that. I’m sure it would be much appreciated by all!
@Mrmike … see the thread (this post) starting with Mark S post discussing the fabric under the bronco sport.
Would you be willing to put together a list of part numbers? Having such a list would be helpful to all Owners that have to replace these.
Here’s two threads but reading the entire post will give you the background information on the topic.
Ford Bronco Sport Fabric Wheel Well Upkeep and Tips 1696083526516
Ford Bronco Sport Fabric Wheel Well Upkeep and Tips 1696083442560
If I can locate the disk and hard drive I copied it to, I will be glade share it. I put it in a safe place...too safe for me to find it so far.
Mrmike
Syracuse, New York 13219
Bucko you're too young for that to happen. Talk to me in conversations if you need another copy.
Bruce
Castro Valley, CA
sites.google.com
I think you can go to the parts department at any FORD . Give them your VIN and get an AS BULIT list of all your parts on your SPORT.
Yes having this thread to quickly get a itemized list of the exact part numbers would be convenient… so thanks to all for their efforts.
BTW My 20’ Ranger has molded plastic wheel well covers So it’s possible to have something similar but again it’s about production and cost.
