- Thread starter
- #16
If you have access to a volt/ohm meter (or multi-meter), set it to DC voltage, and place the black probe on the negative post of the battery, and the red probe on the positive post of the battery. Have a helper start the engine. You should read 13 plus volts at the battery with the engine running (alternator spinning). If less, then alternator is bad.
With engine off, you should read 12.6 to 12.8 volts on a good, well charged battery.
Thank you i will try that with the new battery, this battery was already close to exploding, leaking and shooting steam.
