GoatsyBanks
Josh
New Hampshire
Can you do a measurement at the door joint we’re they meet, from the ground up to the bottom of the molding. Thanks
Ford Bronco Sport Flatout Suspension Level Lift Full Review! IMG_1048
Real quick and off topic...
Can you tell me where you got the grill lights?
I had some on my OB but need to find some that fit into the spaces on the BL
I ordered the tinted ones to match my black lettering.
austin3.16
Austin
Could you tell me what your measurements are from the ground to the peak of the arc each of the wheel wells? Also curious how high up your collars are set on each of the rear springs?
I’m having trouble getting my left and right rear heights to match while also achieving a ~0.5” rake between front and rear.
Reactions: Jrl
B5G4B
2022 BRONCO SPORT
I can measure that for you later. The picture I posted shows how high the rear collars were set. When i picked it up from the shop we went around and measured all 4 tires. THe backs and fronts were equal and there was right at a half inch difference I do remember that.
austin3.16
Austin
Thanks I’ve just posted on flat out’s post so hopefully they can provide some insight as well.
