Sync display black
KennyB
Ken
Wilkes-Barre, PA
Hello,
I have a 2021 Big Bend with 41k miles on it.
Over the past two weeks, my Sync display isn’t working. It shows the startup display, then goes black. When I put it in reverse, the camera displays, but doesn’t turn off when I place it back in drive. If I do a soft reset ( power + right seek ) it works.
Has anyone else had a problem with the display and found a fix?
Thanks for any help
Ken
Simone
Simone
Amherstburg Ontario Canada
Bronco Sport 2021
Im
Hello,
Thanks for any help
Ken
I’m having this issue as well with my 21 Big Bend but have not brought it to dealer yet. I just re-set every time. I have 65,000 km so similar mileage. Very annoying. I hope it’s an easy fix .
Don't think this is really it, but by any chance, did you hit the "screen off" button? I don't know if that is something that persists through key cycles.
Ford Bronco Sport Sync display black Captur
KennyB
Ken
Wilkes-Barre, PA
No. Just randomly goes black after startup. Not every time.
KennyB
Ken
Wilkes-Barre, PA
That’s my next step. It hasn’t happened for the past two days since I originally posted.
It has been quite hot. I’m wondering if it was because of the heat.
Thank you for the suggestions.
PaulOinMA
Paul
MA
Search Ford SSM 51254. My dealer reprogrammed the gateway module after two other attempts at addressing my multiple SYNC issues, including black screen.
I tried system resets. My dealer did a master reset. Second time they reprogrammed the APIM.
Seems better, so far so good, after reprogramming the gateway module.
Hello,
Thanks for any help
Ken
Hi Ken! I can look into your Bronco's screen concern on my end. To get started, could you please send a private message over with the name/location of your local Ford dealer and your Bronco's VIN?
How long has it been since the last occurrence of multiple SYNC issues, including black screen? (After the dealership made the updates)
PaulOinMA
Paul
MA
No recurrence so far of SYNC issues since the gateway module was reprogrammed on June 26.
Simone
Simone
Bronco Sport 2021
I’m still having trouble with my screen going black. Sometimes 3-4 times a day. I guess I’ll have a dealer here in Maine look at it
KennyB
Ken
Wilkes-Barre, PA
Mine hasn’t been acting up since I originally posted. It was very hot for a few days, and since it got back to normal, no issues. Guessing it might be the heat.
CindyC
Cindy
Kansas
I have a 2021 BS OB - screen went black twice in one day. Called FordPass - had to reset to factory settings. So far so good.
