Steeda Rear Sway Bar install
gatornek
Miami
Coming from a Mustang, that was dropped an inch, had a nice front camber, and used to take a 90 degree corner at 30mph like it was on rails, I REALLY FEEL the undertsteer on the Bronco. I'm also a fairly big fan of Steeda. I had their springs, and a bunch of their subframe stiffening bits on my Mustang, and I was always impressed. The Mustang handles beautifully.
So Steeda does manufacturer a rear sway bar for our chassis, including the Escape and Maverick.
Steeda 555-1031 Bronco Sport/Escape/Maverick AWD Rear Sway Bar (20-22)
I've done sway bars before. They are usually not that big a deal to install. Properly tuning the suspension is a different story. But anyway, I noticed in one of the install videos, they mention that depending on the vehicle, we might have to disengage the drive shaft to the rear axle in order to get the old one out and the new one in.
Does anyone have a good pic of the Bronco Sport rear undercarriage? Or can anyone confidently answer if the shaft would need to be disengaged.
MAGPLM
Maple Grove, MN
2022 Bronco Sport Badlands & 2023 Maverick AWD FX4
I did not disengage the drive shaft to take out or install new sway bar. It does take some wiggling and moving around though to get out and in.
MAGPLM
Maple Grove, MN
Putting in my Maverick one this weekend also. LoL
gatornek
gatornek
Miami
Fantastic! Thank you!! How did it help with cornering?
cprcubed
Parker, TX
Probably a nice change if all your driving is on surface streets. Stiffer antisway bars are generally not good for off roading (less wheel travel unless they can be disconnected). Cheers!
gatornek
gatornek
Miami
That's some food for thought. Most certainly 90% of the driving I will be doing in this car will be on paved roads (if not more). However, I did get it for its off-road capability and have already gone on a couple of treks! So I'm enjoying this aspect and hoping to do it more. It was completely unavailable to me in the Mustang.
I definitely would not want to mess with its "off road capability", but the difference in handling has definitely taken some getting used to. Maybe I just gotta understand that I'm driving a truck and not a coupe.:D
Mrmike
Syracuse, New York 13219
I'm curious about this also. I already installed a Steeda strut tower brace on my '23 OBX. I just found out they make a rear sway bar for the BS. Is there currently a factory bar on the vehicle? Is the Steeda advantage because it's heavier and adjustable, or just because the BS does not have one from the factory? I don't off-road but would appreciate a better handling and cornering everyday driver.
gatornek
gatornek
Miami
The only real information I can find on it is from STeeda's infomercial on it. I can take that with a grain of salt. I can't sseem to find info on the diamter of our rear sway bar so I could see what kind of increase it would be. If its a 2mm increase, that's a fairly big deal, because even the bar that they use is of a better quality build (they elabortate on the materials in the part page). But alot of extra stabilization must also come from the adjustable hookup points.
I think the propensity to understeer the BS has gotten better for me, coming from my lowered Mustang to this. But its still there. It's a part I'm looking at. But not even being 2K to the odometer yet, I'm making sure I don't have any bad CV joints, or faulty bearings or even brakes before I start making a change in the suspension. Still worried about warranty items.
FWIW, Steeda has it on sale I think thru today for 4th of July. Its down from $250 to $200. I thought about buying it all weekend long and just storing it in my garage till I'm ready! ?
Cursed Bronco
Dakota
Indianapolis, IN
I bet if you lower it, like I saw someone post in here the other day (name and post alludes me), throw in a stiffer sway bar and the strut tower brace, then it may handle rather nicely for the streets and "high" speed cornering.
Hitman11
E
Houston
That's what I plan to do :fingerscrossed: except for the drop. Hoping to improve the clunky ride a bit with the tower brace and rear sway bar.
Hitman11
E
Houston
Got the rear sway bar installed. Was a PITA but got it done.
Ford Bronco Sport Steeda Rear Sway Bar install 20240612_003602
