New tires and ground clearance after lift
B5G4B
2022 BRONCO SPORT
So for those of you that upgraded tires, how much more ground clearance did you gain and with what tire? I currently have the 235/65/17 Falkens on my badlands. Thanks.
You can go to a 235/70/17 Goodyear wrangler workhorse,they stand at 30 inch and clear without issues. .
Ford Bronco Sport New tires and ground clearance after lift IMG_0817
Ford Bronco Sport New tires and ground clearance after lift IMG_0819
Ford Bronco Sport New tires and ground clearance after lift IMG_0813
B5G4B
2022 BRONCO SPORT
Got it. So that would be a full inch higher than the Falkens I think.
Reactions: Jrl
Winds of Change
Chicagoland
I thought the 70 series rubbed in off road extremes?
B5G4B
2022 BRONCO SPORT
I’m not doing any extreme off-road stuff. Does anyone have any experience with 245/70/17?
Most likely too big, you would get rub when steering to full lock, or somewhere close to full lock.
Even with a lift installed?
Yes, the rub is on the back/bottom side of the wheel well. A lift doesn't really change the relationship/gap between the tire and the point that rubs, unless you figure out how to raise the BS by 5-6".
Your issue would be the extra 10mm it will rub . Mine has 235/70/17 the 235 is the trick , unless you get a little lift , the skinny tire is the answer. Meanderthal has the right math on this subject. This is my own opinion based on the last 4 months of use .
Ford Bronco Sport New tires and ground clearance after lift IMG_5525
delm
Atlanta
This is a hot topic that comes up all the time. I posted about my experience with a lift and 255/70/17 tires and some trimming of plastic. No rub and I really enjoy the ride.
Alfa 2407
Thomas
I intend to run the same size tire, what size lift kit are you running?
Bamsi
Puerto Rico ??
Man, looks good! Unfortunately need better wet grip as I am in Puerto Rico, USA. Too much hurricanes!
