- First Name
- Mark
- Joined
- Oct 30, 2021
- Threads
- 119
- Messages
- 6,733
- Reaction score
- 13,149
- Location
- St. Jacob, IL
- Vehicle(s)
- 2021 Badlands | 2020 Escape
The OEM air/oil separator is just that: It separates liquid oil from the PCV vapors going back into the intake. It won't do much to pull out finer aerosolize particles, or mist. This is fine for an engine running the stock tune, which is programmed to allow for it.Understand the octane reasoning, as the tune is written with octane requirements. It's the catch can/oil separator requirements that I question, as the 1.5 and 2.0 already have one. As other threads here have mentioned, as long as you change your oil at 5K intervals (which I assume you would with the tune's ability to "enjoy" the engines capabilities more), you would not have issues with the OEM's ability to perform what the aftermarket catch can/oil separator does.
A well-designed catch can is capable of pulling out much finer aerosolized particles from the PCV vapors. This is important for two reasons:
1. A "tuned" engine will increase boost pressure on the turbocharger, which will in turn increase the amount of piston blow by--that is the amount of pressurized gases getting by the piston rings into the crankcase. This means an increase in crankcase oil vapors in the crankcase which are then routed back to the intake to be burned off.
2. Crankcase vapors are mixed with the pressurized air going to the cylinders to burn off the oil. Oil is much lower octane than premium gasoline. The more oil in the vapors the lower the ultimate octane of the mixture going to the cylinders. If you're running a tune that is highly sensitive to fuel octane you should absolutely run a quality catch can to prevent octane dilution, which can result in catastrophic engine failure.
