Rhel
Rögnvaldur
Iceland
www.facebook.com
to day I did
Indoor setups Whf radio . Switch board .Garmin gps
Kraken23
Allen
St. Louis, Missouri
2022 BS BL
Not all done today but……
Got the windows tinted a few weeks back, including the sun strip on the windshield. Unfortunately right after I got a chip which turned into a crack and finally a new windshield. Had to get the sun strip replaced.
So today I gave her a good cleaning and also installed the weather tech side window deflectors. Love the look of both.
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_0808
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_0809
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_0810
davidg4781
I finally took it out off highway. I went out to Padre Island National Seashore near Corpus Christi. I drove down about 10 miles then back again.
In the loose sand I used the Sand mode. It handled pretty good, kept revs high, and while I was worried I might get stuck, I saw a Honda Fit so figured I'd be ok. On the more compacted sand near the shore, I switched to Normal mode. I remembered the manual mentioned about not using Sand or Slippery on dry pavement. I figured the compacted sand is closer to that than loose sand.
Ford Bronco Sport What did you do TO your Bronco Sport today? tempImageBNTZpK
If insurance is covering the glass, they will more than certainly cover the tint too, if you can prove it was on there (receipts).
Jonathan
Nova Scotia
bronco sport big bed 1.5l
Ive had my 2023 Big Bends now for 2 weeks, so far ive added a k&n air filter, 20mm wheel spacers, a center console tray, a wireless android auto adaptor, seat covers, and a 9-drive throttle controller. For those interested in throttle controllers they make a massive difference. Save your money amd dont go with the pedal commander, i had one for a different vehicle and it does the exact same thing as the $30 nine drive pedal controller. They really wake the throttle up, massive difference! I plan on doing the 1.5" lift and a set of bigger tires. Maybe a cold air intake system in the future but doutful as the k&n filter and the throttle controller wakes the bronco up pleanty.
CableXJ
Teulon, Manitoba, Canada
Not technically something I’ve done today, but…
My econo mud flaps lasted exactly 32 days before the driver’s side rear had a hole blasted though it by a big stone and the passenger side rear was cracked in several places. The Amazon guy claimed they weren’t designed for stones but I showed him his product description that clearly mentioned “stones”. He sent me replacements that I started coating with low temp, flexible bed liner. Started that today. So far, so good.
