Turn signal/electrical problems?
haroldqjr
Harold
Louisiana, USA
2021 Bronco Sport Outer Banks
I just passed 20k on my bronco sport but today I noticed that my interior right turn signal was blinking rapidly but both of my turn signal bulbs were fine. I went to see if there was anything else wrong with my vehicle and noticed my display had weird lines and pixels on it. I’m going to contact my dealer but anyone else have this and a solution?
Might be unrelated issues.
For the fast blink, check to see if one or more of your brake lights are not working. Don’t forget to check the center brake light on the rear hatch.
For the lines and pixels on the display, I’m guessing you mean the center 8” display? Try
RESETTING THE SYNC3 SYSTEM
1. Simultaneously press and hold the seek up (seek forward) and the audio unit power buttons until the screen goes black.
2. Wait three minutes to allow the system to complete the reset.
3. Press the audio unit power button to switch the system on.
Are you still under warranty? From your avatar info, you may have a year left. If so, take it in for service. These newer tail light/headlight assemblies (if it comes down to tat) can be expensive to replace. I've yet to have to open one up, so I don't even know if their are bulbs, or LED type replacements.
I had a 2020 Challenger that had a front left signal issue. Ended up being a complete replacement of the housing. It was under warranty which was good, as that part was over a grand to replace.
haroldqjr
Harold
Louisiana, USA
My grandfather got the highest service plan when we got the car so I think it should be covered.
haroldqjr
Harold
Louisiana, USA
I’ll have to try that today.
Hi there, I'd be happy to look into your Bronco concerns on my end. Will you send us a message with your VIN and dealership info? I can look into things on my end.
As mentioned, the fast blink is usually caused by a brake light bulb being bad. The signal side that blinks fast is where the problem is.
