- First Name
- Kevin
- Joined
- Mar 16, 2023
- Threads
- 55
- Messages
- 2,494
- Reaction score
- 3,706
- Location
- Gainesville
- Vehicle(s)
- 2023 Ford Bronco Sport Outer Banks Area51
- Thread starter
- #46
I agree to all this with the EPA and such, but why couldn't the process be reversed, meaning it is always disabled, and can be enabled with the dash button, same as being able to disable it after the engine is started? It all still works, so I'd think the EPA is still happy.Right, and the EPA assumes you will not remember to turn it back on again once you turn it off, so the test must be conducted without that system. Ford wants to get credit for the system, so it must default to on every time you start the vehicle. Adding a switch to turn it off is a compromise; Ford gets credit for the system with the EPA while allowing the consumer to turn it off if they don't want to use it.
Your point though on how the EPA assumes you will not remember to turn it off is a valid one (until you realize after the first stop sign or red light you did forget
). I have done that, and so has the wife! A quick push of the dash button stops that from happening again on that trip. Then we park, return from the errand, start the BS, and each of us reaches for the button!I just can't bring myself to spending $90.00 for the aftermarket part that does what I want because of my lack of memory to disable it each time I use the vehicle
.Sponsored
