Swap Instrument Cluster in Big Bend
ranxoren
OT
Bay Area
'22 Bronco Sport Big Bend
Hi everyone! I got a great deal on my Big Bend over the weekend and I'm super happy with it!
That said, one thing I do wish it had is the nicer instrument cluster from the Outer Banks and Badlands model.
Looks like it can be purchased separately and it states that it's compatible with all trims: https://www.oemfordpartsfast.com/oem-parts/ford-instrument-cluster-m1pz10849e
I know someone that did something fitting one BMW digital dash into another and it was plug and play so I'm curious if anyone her has done this and what your experience was?
Thanks!
Dperry285
Dennis
2023 ford bronco sport
Thanks!
It wouldn't make sense since you do have the options for it to show like intelligenant cruise control, lane keeping ect
Sleddog
Bob
2022 Bronco Sport Cactus Grey.
These swaps have been done quite a bit in the latest generation of Super Duty. Most folks go to LKQ for the displays.
it required some programming with Forscan. There also I guy that has the ability to input the correct mileage. It’s been a while since I’ve looked in those threads but it could be a good place to reference. Ford Trucks
ranxoren
OT
Bay Area
Right but it should still work with the options I do have (e.g. I do have lane keeping)
What’s “not nice” about the cluster now?
I'm just coming from a fully digital dash and I enjoy that look and feel so if I can spend ~400-500 to get it done and it's relatively plug and play with minor programming im interested.
Like I said, I was able to get a pretty great deal on a new '22 big bend that made the price of the Outer Banks not worth it. This is the only option I do wish it had.
Thanks for that, I'll do some digging!
Bato001
Usa
Bronco Sport Badlands Hot Pepper Red
I didnt know there were different speedometer panels for different trims but when I googled it turns out there are already 2 or 3 similar threads here on this exact subject.
I didnt know there were different speedometer panels for different trims.
Pics are abit “dated” because the ‘23 Heritage models aren’t listed and the First Edition isn’t listed but is a good visual of the speedometer panels for those not familiar…
Ford Bronco Sport Swap Instrument Cluster in Big Bend 1683908687958
Ford Bronco Sport Swap Instrument Cluster in Big Bend 1683908724299
ranxoren
OT
Bay Area
there are and I did find them searching too but they’re older (some didn’t have any responses either) and didn’t have anyone’s experience since then. This got more responses and a link to a Ford trucks forums that might have insights.
ranxoren
OT
Bay Area
Yeah I kinda want to take the plunge and do it but it’s ~$500 with no clarity of whether it would work plug and play… hoping someone’s done this or has more insights to share ??
Thanks for adding the pics!!
JohnSilver
Knoxville
Only reason I would like to have it is to see speedo and mpg at the same time... First world problems
ranxoren
OT
Bay Area
Yeah hoping someone that’s done this - or that has the knowledge about forscan - can chime in for confirmation! ??
coopny
NY
2023 BS BL
Someone else asked this some time ago, I haven't been able to find an indication that the procedure is supported in FORscan on a cluster switch.
The key part is even if the procedure is supported, FORscan only permits updating the instrument cluster to a higher mileage (as a way to prevent odometer rollback/fraud). That's hunky dory if the cluster you intend to put in has a lower mileage than your car actually has, but screws you if you buy a cluster that has a higher mileage than your car. (I agree with the approach of the ForSCAN devs on this one to prevent easy odo fraud).
I looked at the same thing with my 2015 Fusion and wanting to put in the cluster of a Mondeo (European version) that was all digital and ended up deciding against it even though it was supported as I didn't want to invite questions of odo fraud. If you do it, I would get two minor services at a CARFAX submitting place (like topping off wiper fluid) just before and after the change.
For the Bronco Sport - I haven't seen evidence of someone doing an instrument cluster swap thus far.
ranxoren
OT
Bay Area
Thanks for the insight. Yeah it would be a brand new part so ODO would be raised to match the car (vs other way around to your point).
What would the carfax services be for? To make sure it’s reporting it correctly?
coopny
NY
2023 BS BL
Yes. I would do it to make sure that there was no doubt of odo tampering. Imagine if you swapped the odo 10 months from your last service. Maybe you got a super big cross country road trip or long commute trip job, easy way to disguise actual mileage.
It's why I ultimately decided against doing it in my Fusion. Of course, that was an instrument cluster that was never offered in the US and not one that merely wasn't in the OG trim as built by Ford, but either way the swap invites questions on why it was done. Having some carfax reporting with proof of purchase or the swap date would remove potential questions if the buyer were to notice.
Shanebou24
Shane
Ma
2021 bronco sport
i did it. it was honestly super easy
