One Press Windows
SD_Zach
Zach
South Dakoa
2023 BS Big Bend
Does anyone know if it possible to make the windows a one touch up or down setup?
My 01 ford has this on the driver's side. I figure it has to be something done in the programming now.
magicbus
Nantucket
Rivian R1T, Volvo XC90 Hybrid
Hmmm… mine already are one-touch up and down. Must be a BL feature.
SD_Zach
Zach
South Dakoa
2023 BS Big Bend
I believe a specific module is required to add a load sensor. The load sensor stops window movement if there is an obstruction--like a child's or pet's head.
There are aftermarket options available, but I have no experience with them.
I hadn't even thought of the safety requirements, that tells me that you won't be able to adapt a one touch up at least.
CableXJ
Teulon, Manitoba, Canada
Have you tried the one touch reset already?
If you have disconnected the battery, you must reset the bounce-back memory separately for each window.
Carry out all steps within 30 seconds of starting the sequence.
  1. Close the window.
  2. Press and hold the window control switch until the window is fully open.Keep the switch pressed for a few seconds.
  3. Lift and hold the switch until the window is fully closed.Keep the switch held for a few seconds.
  4. Press and hold the switch until the window is fully open.Keep the switch pressed for a few seconds.
  5. Lift and hold the switch until the window is fully closed.Keep the switch held for a few seconds.
Note: Repeat the procedure if the window does not close when you use one-touch.
Thanks. I’ve tried that several times. Never disconnected the battery. Only my driver’s window has any kind of auto feature. Only auto Down works.
seoden88
Scott
Louisville, KY
'22 Bronco Sport Badlands
No. It's two different window systems. Only Outerbanks and Badlands get one-touch up and down.
ipage
Isaac
Mackenzie British Columbia
2022 Bronco Sport Big Bend
I believe it is only available on the Outer Banks and Badlands models, I sadly do not have it on my big bend.
SD_Zach
Zach
South Dakoa
2023 BS Big Bend
I understand why a one touch up would require a different setup from the factory. But the one touch down should not, the window would roll down until it reaches the bottom, no different than holding the switch. I understand it is "lazy" to want the one touch option. But so is power steering or electric windows for that matter.
seoden88
Scott
Louisville, KY
the lower models is not a smart switch. the architecture is different. its not possible
SD_Zach
Zach
South Dakoa
2023 BS Big Bend
So if I hold the switch it will continuously run down and burn out the motor?
My post was incorrect.
In the Owners Manual (Power Windows Section), there are separate sections for the One-Touch power windows function and for the Bounce-Back power windows function including separate procedures for resetting those functions.
Both functions state (If Equipped)” as not all Ford vehicles have one or both of these functions. For example, my ‘22 Bronco Sport Badlands with Premium Package has the One-Touch power windows function but I don’t know if it has the Bounce-Back power windows function.
The sections of interest are:
One-Touch Down (If Equipped)
One-Touch Up (If Equipped)
Resetting One-Touch Up
Bounce-Back (If Equipped)
Resetting Bounce-Back
See the Owners Manual for the One-Touch and for the Bounce-Back power windows functions.
(Or see Post #3: https://www.broncosportforum.com/forum/threads/auto-window-up-rear-drivers-works-at-times.3831/)
