Remove Warning Labels on Visor?
milamookie
Tuan
I removed the visor labels on my weekend project car. Much more common thing to do in the modified sports car world than the off road world. I used Goof off. Much easier to do on a new car vs a 20 year old car.
JimC
jim
SE Michigan
2019 Ranger 2022 Bronco Sport
Just did a search "auto visor cover"
there is a boat ton that came back & you dont have the mess to deal with
Cactusjk
Jeff
Woodland Hills, CA
I hate removing visor stickers because you can always see where they were. I use Blue Ridge Overland Gear visor organizers.
Mrmike
Syracuse, New York 13219
I got mine off today with a heat gun on LOW! A hairdryer will work too. Pick at a corner with your fingernail until there is enough to grab. Warm it up slightly, and it will come off in one piece. I keep my visors down most always; To me, this looks much better.
Be advised... There is still a visible residue even after mildly scrubbing with different solvents, including acetone. Can't see it unless you're holding them up to the light. IMHO: Not noticeable when mounted.
Ford Bronco Sport Remove Warning Labels on Visor? 20221009_145511
Ford Bronco Sport Remove Warning Labels on Visor? 20221009_154938
Does the heat gun have any ill effects on the Homelink Garage door buttons?
Winds of Change
Chicagoland
I can not believe how long this thread has lasted.
PMM
Seattle, WA
2021 Bronco Sport, 2021 Mustang Mach-E
But then how are you reminded not to drive with a baby in your lap?
Mwittke5857
Elma, NY
2021 Bronco
Has anybody removed the warning stickers that are on the visors? I know they probably should stay there, but I really don’t want them. If anyone has removed them, what method did you use, and were you happy with the results?
Heat gun or hair dryer typically looseness them enough to peal off in one piece. I use 90% Alcohol to remove any residue that remains
bdigna
bdigna
Bruce
Detroit, MI
The heat gun worked great, but got my fingers a little warm. The hairdryer, not so much. Still need to hit the residue with the alcohol
freebob
bob
mi
bronco
Use goo be gone. it takes it off completely
bdigna
bdigna
Bruce
Detroit, MI
I will try this - tried 90% alcohol yesterday, but that didn't work. Not sure if I should have let the alcohol soak there for a bit. Goo Gone won't "melt" the vinyl?
freebob
bob
mi
bronco
no it's mild mire used it on mine..
