Small Utility - BabyB
Jalisurr
Dave
Vancouver,BC
'97 Mitsubishi Pajero Evolution, '09 Corvette Z06, '08 ZX-6R
Expect the 2/4 door Bronco's to be about 190 inches long. The closest we have to compare to is the Ford Everest, the SUV off the Ranger, which is 192 inches long for a 4 door model.
The frankenranger mules may not be representative of the final body but there's no reason they wouldn't be representative of the final wheelbase. If those two door mules running around end up with a 190 inch long body on them they'd have ridiculously long overhangs front and rear.
BroncoBronco will be similar in size to the wrangler. 160ish for the 2 door, 180ish for the 4 door.
Jalisurr
Dave
Vancouver,BC
Why the Wrangler is 166.8 to 188.4″ long and Ranger frame isn't going to support something that small without a significant redesign...where are you getting that info?
1) BroncoBronco isn't on the T6 frame, it's on a new frame that will be shared with the next gen Ranger.
2) It's a pickup frame, taking length out of them is not difficult. Hence how they can make the shortened Frankenranger mules in the first place.
Sherminiator
Scott
CNJ
Taurus SHO
1.Why would a 2 door Bronco need a 4 door body on it? That makes zero sense
2.The 2 door Bronco will not be smaller in OL vs the Baby Bronco.
The terrible photoshops here of the Baby Bronco and FrankenBronco mule are amusing at best-they don't even have scaling down properly to make a good comparison.
Jalisurr
Dave
Vancouver,BC
Hey, I'm just going off what you just said. I totally agree it makes zero sense! The wheelbase of the 2 door frankenranger with a body over 180 inches long would look ridiculous, but that's what you're claiming right here:
The Baby Bronco will be roughly the the size of the 2020 Escape-Overall length of 180 Inches
I'd love to hear where you're getting this supposedly authoritative information when literally everything else including the intended competitor indicates that the 2 door will indeed be smaller than the 180ish length of the Baby Bronco.
Dirty Bronco
Brad
Cleveland
2015 Ford Explorer
If someone can provide me with a profile view and and a known dimension on the vehicle I can calibrate it on my computer and post my findings. I can do this for the frankenranger or artist rendering. Only thing that could be "known" on a rendering is likely a tire or rim used on another vehicle.
BroncoMike
'71 Bronco, '02 Excursion, '22 BS
The FrankenRanger/Bronco 2 door is not indicative of what the 2 Door Bronco will actually be. The mule doesn't even allow for any rear impact standards
With that said, the last gen "full sized Bronco" was only 183 inches long and the Bronco II was 161 inches long before it was replaced by the Explorer.
So both new Products are going to be dramatically bigger then the older ones.
Source? What you've written in regards to the 2-door U725 flies in the face of most of the current speculation. Is your data simply more speculation, even though outside of the currently accepted envelope? I'm trying to envision a 190" 2-door, and my imagination fails me.
Jalisurr
Dave
Vancouver,BC
I think this is the closest we've had to a straight profile shot. I believe those are known Ford rims but I'm not 100% sure what size
Ford Bronco Sport Small Utility - BabyB ford-bronco-spied-2-
That would be the 4 door mule, the 2 door is even shorter:
Ford Bronco Sport Small Utility - BabyB 2-door-2021-ford-bronco-two-door-prototype-jpe
Sherminiator
Scott
CNJ
Taurus SHO
I updated my post-maybe you you used your head-I was talking about the 4 door, not the two door models-maybe use your brain.
The frankenrangers have zero indication on how long or short the vehicles are going to be-they are hacked together from spare parts for engineering (engine/frame/platform) work and not aesthetics.
Dirty Bronco
Brad
Cleveland
2015 Ford Explorer
This is perfect. If someone with better knowledge could provide the known dimensions of the rims and or wheels I can get us taken care of with dimensioning purposes.
Sherminiator
Scott
CNJ
Taurus SHO
Both vehicles (Ranger/Escape) use 17-18 inch rim size (Outside of the Escape Ti that has a 19 wheel)-I don't think an inch will throw off them off. The actual tire sizes might be able to get from the spy photos.
Dirty Bronco
Brad
Cleveland
2015 Ford Explorer
17-18" variance over the span of the 170-180" vehicle is just that.. A difference of 10". So if we want it to be accurate it does matter unfortunately. I'll look into the Escape and Ranger rims to see if I can find a match.
Toyhoarder
The west
Early Bronco, F-150, F-450
Maybe you you you you could use your brain.
Your post still says the 2 door Bronco will be about 190 inches long. Then claims it will obviously be shorter than that? WTF kind of info is this?
Jalisurr
Dave
Vancouver,BC
The FrankenRangers are totally not indicative of body length, correct. However, as they are intended for engineering the frame and platform, the wheelbases should be correct, and for good off road geometry we know they won't want huge front and rear overhangs.
To be clear, are you still claiming the 2 door Bronco will be over 180" long? I just can't see that happening with what we've seen and been told, and would love to know your source for that.
Sherminiator
Scott
CNJ
Taurus SHO
On the Frankenranger-those are 17" F-150 wheels
