May we inquire to why your front end and half your new bronco is missing . .?With 130 miles on the clock, it is time to tear down and reassemble:
That's a game changer. That panel just comes off with a trim tool? Then you notched the side or just left it off? Like someone else said, there's room for an aftermarket part here. Even just a replacement cover with a couple of those standardized ball mount posts so you can put anything compatible on.Dash mount!
I think putting a couple of RAM ball mounts would not be a bad idea.That's a game changer. That panel just comes off with a trim tool? Then you notched the side or just left it off? Like someone else said, there's room for an aftermarket part here. Even just a replacement cover with a couple of those standardized ball mount posts so you can put anything compatible on.
Eric said 130 mile check up!May we inquire to why your front end and half your new bronco is missing . .?![]()
after seeing this removal, I figured I could build something stable from the screen mounts and use the cheap Amazon aftermarket cover to clean up the space. Just notched through it.That's a game changer. That panel just comes off with a trim tool? Then you notched the side or just left it off? Like someone else said, there's room for an aftermarket part here. Even just a replacement cover with a couple of those standardized ball mount posts so you can put anything compatible on.
You’ll find out pretty soon.May we inquire to why your front end and half your new bronco is missing . .?![]()
Gotta admit I'm jealous of those graphics. I suppose I should get busy with the cricut.AVS Bugflector installed. Mountain window decals installed. Mountain over Ford logo installed. 3rd brake light decal installed.
You should! Adding a little something helps to break up the "WHAM" of the Velocity Blue. I'm keeping a simple and clean blue and white build. Only thing I'm planning to accent with a bit more color are the tow hooks. The ones already on the vehicle complete all the graphics I planned on adding so I don't make it too busy.Gotta admit I'm jealous of those graphics. I suppose I should get busy with the cricut.
Let’s just get you back into this nice white jacket with the extra long arms and then you can rest in the nice soft room with the pillow walls.Other than the floor mats and cargo area mat I haven't made any additions to my Bronco. Is there something wrong with me that I just love it the way it is?
Looks like you're gonna need the one with four sleeves.Let’s just get you back into this nice white jacket with the extra long arms and then you can rest in the nice soft room with the pillow walls.![]()
I popped mine off this morning. The center screw (M5-.8) is pretty deep under the cover. looks like if you did a 1 inch ball that has the 1/4-20 tapped hole, you could just drill a hole in the cover and add a black fender washer on the outside and a 1/4-20 bolt and fender washer from the inside. The 3 inch B clamp puts my GPS right above the center screen. I might see what I can do to make a part that mounts directly to the center mount to make it more rigid.That's a game changer. That panel just comes off with a trim tool? Then you notched the side or just left it off? Like someone else said, there's room for an aftermarket part here. Even just a replacement cover with a couple of those standardized ball mount posts so you can put anything compatible on.
