Brake pedal click
Sobieski
Dale
Bronco Sport - AKA Mulder
Anyone experience or feel a click in the peddle when you first begin to depress it. After a few minutes of non use. I added some grease to the peddle and it is like 50 better but still there. Adding more grease has not stopped it.
Major Kong
Major
Right Here Right Now
Bronco Sport aka "Spark Plug"
Ford Bronco Sport Brake pedal click 1661136261644
Obvious typo error OP
allow me
Break Peddle Clique
tjbronco
You sure it is not the brake light switch? They normally will click a bit. Not noticed specifically on the Bronco, but I will listen for it...
Sobieski
Sobieski
Dale
Thanks I’ll check with recall. No there is no noise but ya feel a slight stick. Never back to back but intermittent. Just very annoying.
Major Kong
Major
Um, hello. How do you know he is actually not referring to a break peddle?
I'm known to be fluent in two languages
primary English
the secondary of which I have mastered is gibberish
the two intertwine at times being hard to differentiate
pandemonium and gibberish it's my life's calling
you're correct
we're dealing with a mixed language
primary English
you're correct
Amazing that your post about fluency in two languages is probably the most English based I have seen in a while. Generally the gibberish seems to have the upper hand.:giggle:
brynamic
KC
I notice what you’re describing. The used ‘21 I test drove did it also.
Sobieski
Sobieski
Dale
oops! my bed!
Sobieski
Sobieski
Dale
Well around 7,000 miles the click I feel depressing the brake has gone away.
