20" Do fit !
tlg_3
Taylor
Ordered ā€˜22 OBX
Clearance is perfect. Have no rubbing at all lock to lock. But it's close like maybe 2 mm from the wheel liners and mud flaps at full lock... also fooled around in the yard ( have 5 acres) and still no rubbing.. i know its no trail but thats all i can report to date... opinion is if you go with a wheel which more depth the wheel will stick out farther and will rub on wheel wheel liner... I believe..... not an expert lol...
Thanks this is what I needed to know.
Did u guys test it on full compression suspension hits ? Will you do damage when turned and drop in a pot hole ?
thisgr8ride
thisgr8ride
kevin
red deer alberta
2021 bronco sport outerbanks
mine does not hit, but stock suspension with bigger tire and rim. not lowered.
Spitty
Chris
Lancaster, PA
Finally got around to installing the new wheels and tires on the wife's OB today after work .
Before:
Ford Bronco Sport 20" Do fit ! 20211209_132339
After :
Ford Bronco Sport 20" Do fit ! 20220404_183908
20x8 riffino inceptions on 245 / 50 / 20 toyo AT3 No rubbing lock to lock .
No lift No mods just on stock OB.
You BS looks sick! Can you send a link to the rims and tires that you installed?
thisgr8ride
thisgr8ride
kevin
red deer alberta
20x8 riffino inceptions ( rims )
245 / 50 / 20 toyo AT3 ( tires )
Got them from grizzly trucks here in Alberta.
V8 Yankee
Harold
Miami
21 Bronco Sport
Looks nice, your OB is the same color as mine. The wheel color really compliments the black. I'm going with 20s also, as u are the second forum user that sized up on wheels with no problems. If u get chance write an update after a few hundred miles. I'm curious about your POV on ride, handling, milage. Again, looks awesome, sets your OB apart from the others.
Ok
thisgr8ride
thisgr8ride
kevin
red deer alberta
Ok
who is the other user with 20" rims, did a search but couldn't find, what style rim did they use?
Spitty
Chris
Lancaster, PA
I can only find the Ruffino Inception rims in 20x9. I scoured the internet too. Are you sure they are 20x8?
thisgr8ride
thisgr8ride
kevin
red deer alberta
Jcera304
Jason
Huntington, WV
Your BS looks amazing! I’m really considering going 22’s or 24’s. I like the way it rides from the factory so I don’t want to lift it. I’m not doing any off roading any time soon. Mainly just wanted to have the AWD for the winters. I’d obviously switch to a set of winter wheels and tires if so. Just gotta save up my pennies lol. I can’t find anyone that has any info on bigger wheels than 20ā€ on a BS tho. Again, it looks really great!
2025 Badlands Sasquatch
If you're happy with them, good on 'ya, mate.
For my own taste, though, ewww! :)
