Driveshaft Recall
ChupaKobra
Palm Desert, CA
Taking my FE in tomorrow for a faulty driveshaft replacement.
Apparently there is a recall coming out soon for this very issue in case anyone else is starting to experience similar symptoms. Anytime hitting the gas (most notably on an incline) the entire vehicle shakes & rattles.
16k miles.. first issue with drive-ability or warranty needs.
zachc275
Zach
BS Outer Banks (Area 51)
Did you experience this or just get a recall notice? I feel like I've seen this issue mentioned here at least a few times, so not surprised in the slightest that there's a recall...
Looks to be an older recall.
ChupaKobra
ChupaKobra
Palm Desert, CA
After a road trip, it became more and more apparent on the freeway. Once I took the vehicle in, the tech mentioned that Ford would be announcing a recall for this issue in the coming months because they’ve been having so many sports come in with the same issue.
Fossil
Ernie
ohio
Ford Bronco Sport Driveshaft Recall 1656289620963
link: https://www.kbb.com/ford/bronco-sport/2021/recall/
says driveshaft but then goes on to describe axle?
actually it says, power train: driveline: driveshaft as sort of a catch all heading but as you allude to it only discusses the rear drive unit.
This is a old, long gone issue that happened during launch. 147 units effected. That doesn't mean you should ignore any fluid puddles on your driveway, from either end. ?
Asked my mechanic stepson about a driveshaft issue, his service dept hasn't had any.
bjbena
Barry
Escape SEL. EcoSport SES
Man, you're 'lucky.' You're one of 147. Impressive.
