Custom Letters for Rear Hatch
LilbroncoS
Brandon
2021 bronco sport
Just throw a 4 foot level across. Draw a horizontal line with a dry erase marker to put letter straight. I would even grab a torpedo level for the vertical lines evenly spaced. Would come out good
HUSBANDOFBS
James
Kentucky
2024 Toyota Rav4 Hybrid
Working on Ford's style for all letters and numbers. Once done, I'll post up the .stl files for all. If any of these look wonky to you, point them out and we can work on 'em.
Ford Bronco Sport Custom Letters for Rear Hatch alpha
SAMPLE .STL TEASER OF "BADLANDS".
Ford Bronco Sport Custom Letters for Rear Hatch BADLANDS TEASER
Working on Ford's style for all letters. Will work on numbers tomorrow. Once done, I'll post up the .stl files for all. If any of these letters look wonky to you, point them out and we can work on 'em.
PS the letters are NOT aligned in this image.
Looks great. I think that's all anyone would need with proper.sizing and access to 3D printing with 3M adhesive.
Major Kong
Major
Right Here Right Now
Bronco Sport aka "Spark Plug"
You have now entered stage 1 pandemonium
Exiting is encouraged
Consider the following
Bronco is parked on non-level spot
Ford Bronco Sport Custom Letters for Rear Hatch 1652663053277
Kong - veteran of countless pandemonium conflicts
HUSBANDOFBS
James
Kentucky
**** These files are defunct, GO HERE for the most recent files ****
The entire alphabet and all numbers .STL files ready in 2 aspect ratios. Sample below:
Ford Bronco Sport Custom Letters for Rear Hatch aspects
#1 is as seen in this common image.
Ford Bronco Sport Custom Letters for Rear Hatch common
#2 is what is used for the actual on body lettering and the files are sized for a match. (dang close, anyway)
Of course you can always resize to whatever you desire.
CLICK ME! to download a zip file containing ASPECT 1 sized lettering.
CLICK ME! to download a zip file containing ASPECT 2 sized lettering.
If I have messed up, or you have a question, let me know!
If you print some, POST 'EM UP !!!!!
Michael G
San Francisco
No need to do 3D printing..All you need to do is find a sign shop that does laser cutting or CNC routing and they can cut out whatever font you want on aluminum or plastic and put an adhesive backing on it before they cut it so the letters will be ready to peel & stick on. I am sure there are shops in your area that do this. Anyone who has the technology should be able to help you layout the letters and make them.
nakeff
Steven
Houston, TX
2020 Corvette, 2018 F150 Platinum, Honda Civic
Hello!
I'd like to remove the BRONCO SPORT lettering off the badlands model I picked up and replace them with custom letters, ideally in the same script. I'm having trouble tracking down after market letters for this that aren't vinyl coverings. Do you have any suggestions? I could do vinyl at all but it would be cool to have the raised lettering.
Thanks in advance! If there's a thread about this already, please point me in the right direction. I didn't find much relevant in the search.
I just replaced my daughter's white letters with Black original Ford parts.
SenzeiReese
SenzeiReese
AJ
Ohio
www.etsy.com
So all the shops I spoke with were quoting upwards of $700 to machine these due to the size and individual letters. I opted to resin print them and keep them a bit thinner than the stock letters. They finished today, I just need to clean up any leftover supports.
I'll put 3M automotive tape on them, cut to size, prime and paint in a slightly metallic white, use automotive clear coat, and then replace the stock letters. If these have trouble, well, I'll print them again.
Not possible without @HUSBANDOFBS! Thank you.
Ford Bronco Sport Custom Letters for Rear Hatch ?hash=efee77d3dd35630b0bd8eadccd343c
HUSBANDOFBS
James
Kentucky
WAY COOL !!!!!!!!!!! Please post up when all done !!
