PonyDriver43
Roger
NE FLA
Played around with OBD Fusion app today. Lots if idling, also got an Android app going (no photos). Definitely killed my MPG for this tank of fuel.
APP says Boost is a calculated PID so cannot speak to it‘s accuracy. APP does have PIDs for Intake Manifold Absolute Pressure and Atmospheric Pressure. Maybe APP subtracts Atmospheric pressure from Manifold Absolute Pressure. I’m not a tuner so not up on that magic. It definitely reflects “Boost” when you roll into throttle on Sport mode.
Ford Bronco Sport What did you do TO your Bronco Sport today? 1650844386366
What he just said !.? + or - boost .
PonyDriver43
Roger
NE FLA
Agree APP could use a better illustrated gauge. For this one maybe - boost could be interpreted as vacuum. ???
At idle it will be in vacuum. Even sometimes when you are driving at a constant speed, it will be in vacuum. Under load (accelerating) it will most likely go into boost.
Cactusjk
Jeff
Woodland Hills, CA
Can someone point me to where I can get center console organizers?
Jmuns
2022 Bronco Sport BL
Cactusjk
Jeff
Woodland Hills, CA
Jmuns
Cactusjk
Jeff
Woodland Hills, CA
Jmuns
Which one is that?
Check the pictures. It’s another organizer that fits on the dash behind the screen. Fills the empty space. Most people have it as well.
