Will Bigger Tires affect ABS?
JackisDunn
Jack
Connecticut
Ford Bronco Sport Outer Banks
Hi All!
Dumb question I wanted some input on! Will swapping my 225/60/18s on my OB for 245/65/17s affect ABS?
Cabezone
Cherokee Trailhawk
Larger tires won't affect ABS but heavier tires are harder to slow down, so braking as a whole gets worse. However it's a pretty negligible effect.
Fossil
Ernie
ohio
The pulse frequency will be very slightly less as Ford computers looks at that 80 times per second and reacts to big swings for ABS and traction control. Shouldn't be an issue.
JackisDunn
JackisDunn
Jack
Connecticut
Could you explain that as if you were explaining to a child something with crayons
Fossil
Ernie
ohio
maybe but I'd need carpal tunnel surgery afterwards. I probably shouldn't have mentioned traction control as it gets into sideways skids as well as forward traction as it relates to traction control. I was only referring to forward traction. Pulse frequency was referring to the ABS sensor and ring. Check out the attachment and see if it helps.
https://apecbraking.co.uk/Resources/TechniciansGuides/ABS-Sensors.aspx
