Who here can 3D print me something?
I need a simple spacer made. Nothing extravagant. I just can’t find anything anywhere. I’d rather pay someone in here to make me one.
Can you describe it in a little more detail? Where/how to be used, basic dimensions, etc.
I’ll draw something up shortly and post it. I was hoping you would reply, as I remembered you’ve posted about 3d printing before.
Essentially, I’m after something like this… from an exhaust clamp.
I’d imagine it would be pretty easy to make?
Ford Bronco Sport Who here can 3D print me something? IMG_4134
Ford Bronco Sport Who here can 3D print me something? IMG_4135
Ford Bronco Sport Who here can 3D print me something? Grainger_2dCAD2023xxg3478221
There’s the dimensions of the u bolt I ordered.
So what's the planned use? What will it mate against, what kind of stresses/torque will it have to withstand?
It’s essentially just going to be a spacer. It’s not going to be supporting any weight. The filter that it’s a spacer for already has a mounting bracket. This is just being used so it sits level.
So, I would need two spots in the area between the openings for the u bolt, that I could secure bolts through. It’s going to be mounted to 304 stainless sheet metal.
It just needs to be an inch tall in the middle, and then the radius of the 3.5” filter housing has to somewhat look like the referenced exhaust clamp above. So, probably about 5” wide with the 3.5” on center 1/2 holes added for the u bolt to go through. And then maybe an inch deep.
Will this be a high-temp area?
OK, working on a couple prototypes right now.
DM me a good address and I’ll ship them your way for evaluation and comments.
Sounds good. 😊
