Which JCR skids plate to instal first?
DesertRat19
DesertRat19
Will
Phoenix
You should check some of the early posts, of those people who actually installed the JCR's, on their Badlands!
[/QUOTE]
I tried finding prior posts but didn't see any. The total cost for the set I posted above is $1,543 before taxes
NMhunter
Albuquerque
BS Badlands
Look up my previous post on the installation. I installed the JcR skid plate on the driver's side because I ripped the carpet on my first trip off road. The Badlands came with a small skid over the fuel pump (if I recall correctly), but it doesn't cover the gas lines. The JCR plates come with both sides. I couldn't see a need for the passenger side. Nothing important on that side. It was very hard to drill through the pinch weld on the frame until I bought an inexpensive Cobalt drill set on Amazon. . I wore out. a couple of DeWalt bits and took 1/2 an hour to drill one hole. I drilled all of the holes easily with the Cobalt bits.
You do have to remove the gas tank skid plate and cut it to fit. It isn't difficult to cut if you have an angle grinder.
The hardest part of the job was getting the gas tank skid plate off. It was LocTited on. I had to use a mini torch to burn off the LocTite before I could remove it. It is a bit dicey right next to the gas tank. I had a fan going, and a fire extinguisher at hand. I tried everything in my tool set to get those button bolts off before the torch. The air impact wrench just stripped it. Once I burned off the Loctite, it was easy to remove.
I drive a lot of roads that are rutted, and the BS lacks clearance even with my 1-1/2" lift and 30 inch tires. I was plowing snow and rocks with my Catalytic Converter on some trips a couple of years ago, and decided I needed that skid plate. It was easy to install, and I have scratched it many times since.
I think most people would be better off getting the cat skid first.
DesertRat19
DesertRat19
Will
Phoenix
Thanks you think then buying the gas tank skid along with the evaporator & floor skid make sense since the factory gas skid has to come off anyway? I watched the install video from JCR and they already had their gas tank skid installed
Winds of Change
Chicagoland
Hello, looking to add some extra under protection to my Badlands. I am leaning towards JCR skid plates but not sure which order to instal them? I can't do all at once so maybe one or two now then more next year. The options are:
-Evap and floor skid
-Gas Tank Skid
-Engine skid
-Front bumper bash plate
-Catalytic converter skid
The Badlands already has some skid plates. When I had my 2023 Bronco Sport Badlands I added some. I got the JCR skid and sliders combo. I needed to buy the two skids for underneath to be able to install the sliders. I was pleased with them.
Ford Bronco Sport Which JCR skids plate to instal first? 1000002280
Ford Bronco Sport Which JCR skids plate to instal first? 1000002551
NMhunter
Albuquerque
BS Badlands
Since the Badlands already has a gas tank skid plate, there is no good reason to pay $300 for another one. Buy an angle grinder instead. It isn't that difficult to cut it to fit. The fit doesn't have to be perfect since there is some overlap.
I never knew how useful an angle grinder is until a friend gave me one. I don't know how I got by without it for all of those years.
incavulator
Scott
Installed the JCR engine skid on my BL a couple months ago. It's a pretty nice piece. There were some minor fastener issues, but I worked through them and JCR sent me some extra washers at no cost so I'm pleased with their customer service. I upgraded to the version with the oil change access door so I didn't have to remove the entire plate to do an oil change... something Ford should have done, in my opinion.
For Christmas, I asked for and received the HRG bash plate. I read on one of their sites that that they work together, and I guess they do......BUT, the HRG bash plate covers up the oil change access door on the JCR skid. I wish I would have known that before I ordered the JCR engine skid. I think I'll cut a hole in the bash plate to allow access to that door.... otherwise, I wasted my money on the upgraded version of the JCR skid AND I'll have to drop the entire HRG bash plate to do oil changes.
Also, I'm not entirely pleased with the fit of the HRG bash plate. It hugs the fascia in the center but leaves a 1/4" gap on the outer edges. I can make the passenger side fit better by loosening the rear most bolt on that side but I can't get the driver's side to do the same. Even if I could, I would be concerned the bolts might work loose. Also, HRG provides standard bolts and the hex heads are fully exposed. I'd be concerned that these might be damaged in heavy use. They provide spacers to put under the bolts. I wish they would have just welded in recessed pockets to make the bolt heads flush. In addition to eliminating potential damage to the bolt heads, it would have eliminated the need for the spacers. If I get real ambitious, I might try to fix this too.
I'm going to add these to my list of things to improve. I'll report back if I have any success.
incavulator
Scott
Sorry guys... what am I missing? I researched everything I could find in this forum before making these purchases. I even did a subsequent search following your replies above. Did someone already figure this out and I missed it (twice)? Are you suggesting there was a better option? Maybe you have a link you can share?
Thanks
