TPMS Readings.
Mrmike
Syracuse, New York 13219
Just checked the TPMS readings for both my vehicles. Most were good with some several pounds high or low. I made the necessary changes. When I started both vehicles, the TPMS readings had not changed. How long does it take the TPMS system to detect changes and makes the adjustment to the screen?
V8 Yankee
Harold
Miami
21 Bronco Sport
I check my pressure regularly. Takes only a minute or two while driving freeway speeds.
BigPhatPaulie
Matthew
Alberta, Canada
TPMS wont typically update until the vehicle is driven AFAIK. You should always use a manual gauge if you aren't already and then double check the TMPS after driving for a bit
Tigger
Tigger
Illinois
That’s odd Mike. This last weekend I deflated my tires, checked the system and it read exactly as the pressure gauge. After a few hours of playing, inflated the tires, and the reading was exact again. Each time was about 5-10 minutes after using the compressor and no driving.
mikeyncc
Durham NC
TPMS sensors use a centrifugal switch to turn them off and on. Tires need to be spinning to activate. At least that's how it use to be
