Uh! Mine has moonroof.
Should I avoid setting up the tent?
What’s the max load capacity in my case?
Dynamic load (Load while driving) is 100lbs with the moonroof and Static load(Parked) is 600lbs. You'll be fine with it up there, just don't drive like a maniac around corners.
cristiangrojas
Cristian
Colombia
Bronco Sport Wildtrack
Gotcha!
Thanks for the clarification.
What would be my speed limit while carrying the tent?
Gotcha!
There is no speed limit if you don’t exceed Ford’s dynamic weight limit. If you do exceed the weight limit there is no data available on which to base a recommended speed limit.
