Tailpipe Extensions
tconstan
Garnet Valley, PA
Slingy
Ben
North Of Boston
2021 Bronco Sport BL, 1970 T-Bird, 1972 T-Bird
I don't really know of anything but any time I've considered the idea of exhaust tips I remind myself that there's a reason that the factory exhaust is tucked up and out of site with nothing fancy on the muzzles. Protection and maximized departure angle. If you never plan on doing any off roading then you won't have an issue but if you do you're that much more likely to snag your tailpipes on something. Otherwise you could check with your local custom exhaust shop. They might even be able to create what you're looking for.
SgtT11B
El Segundo, CA
There is a reason why the tips are the way they are. If you have the tips stick out you hurt the approach and departure angles.
Tikihead
Paso Robles Ca.
2023 Bronco Sport , 2022 Maverick Hybrid Lariat
Go on Amazon, there are a lot of options a pair shouldn't cost more than $35.00. And if you want to do some serious wheeling they will come off very easily just as they go on.
tconstan
Garnet Valley, PA
I've seen the angled extensions but I think they will still have a downward bend.
